Dual USB Outlet (Backseat\Cup Holder) Installation
Discussion in 'Technical Chat' started by montgomb, Nov 7, 2015.
  1. May 10, 2016 at 6:23 PM
    #41
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    @Iggy. You have my curiosity peaked
    GARSHA91 and Unchained 5150 like this.
  2. May 10, 2016 at 7:44 PM
    #42
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Thanks for the kind words @DCSBFTMFW!
    @b.prall let me know what your looking to accomplish and I'll let you know what I can do!
  3. May 10, 2016 at 7:46 PM
    #43
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Speaking of which.. you have time in the next few weekends to get my switches squared away? @Iggy.
    We can be quick, lol.
    Not this weekend but possibly one of the following.
    Iggy likes this.
  4. May 10, 2016 at 7:55 PM
    #44
    Iggy
    Northern CA
    Check out the build
    For sure! Let figure out a time and I'll get you squared away.
    T4RFTMFW[QUOTED] likes this.
  5. May 10, 2016 at 7:59 PM
    #45
    T4RFTMFW
    Okay I'll text you next week. :thumbsup:
    Maybe @Bentrodder can come too and get his other switch done.
    Bentrodder likes this.
  6. May 10, 2016 at 8:09 PM
    #46
    Iggy
    Northern CA
    Check out the build
    Yeah! We've been trying to finish his up too!
    T4RFTMFW[QUOTED] and Bentrodder like this.
  7. May 11, 2016 at 4:30 AM
    #47
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    T4RFTMFW likes this.
  8. May 11, 2016 at 1:33 PM
    #48
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Would you possibly draw this out on 4th grade level? I am sure I could cut and paste wires.
  9. May 11, 2016 at 1:45 PM
    #49
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
  10. May 12, 2016 at 9:18 AM
    #50
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Instead of running wires and adding things, could you remove the power supply under the hvac controls and just swap that receptacle out for the dual usb one like in the OP? I'm no wire wizard, just a thought of mine. I would like to do that since I don't use it for anything else and there is 2 of them.
  11. May 21, 2016 at 4:46 PM
    #51
    dblj70
    dblj70 Well-Known Member
    Jeff
    2013 DCSB TRD Offroad SpruceMica
    Since there are members here chiming in that have knowledge in wiring, I'd like to ask a question. I already did the lighted glove box mod and used a add a fuse for it. I used the 15A PWR OUTLET spot. Would it be safe to tap into that wire (running to the glove box) to power the new USB outlet or should I use a different power source? My concern is filling up my fuse box with add a fuses.
  12. May 21, 2016 at 4:48 PM
    #52
    Iggy
    Northern CA
    Check out the build
    Which power supply are you talking about, the 100v one?
  13. May 21, 2016 at 6:05 PM
    #53
    dblj70
    Jeff
  14. May 21, 2016 at 6:52 PM
    #54
    Fiend13
    Chad
    I suppose that's it. Just one of the power points under the a.c. controls. I normally plug the usb adapter into it so I can charge my phone. There are 2 of them and wouldn't mind converting one to a fixed usb port
  15. May 21, 2016 at 9:19 PM
    #55
    Iggy
    Northern CA
    Check out the build
    I think you'll be safe for just a USB charger. The biggest I've seen are 2A so those aren't a big concern.
    Oh your talking about the cigaret outlets. Yeah, tapping into those isn't going to hurt. I'd still run them independently if your going through that much work of taking your dash apart.
  16. May 21, 2016 at 9:25 PM
    #56
    Iggy
    Northern CA
    Check out the build
    I have the parts for the setup I posted above. I can build it for anyone who wants it.
  17. May 21, 2016 at 11:47 PM
    #57
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    All of the fuse slots are 12v, and amps are decided by what you are powering. If you use a fuse tap(aka:add a fuse, etc), then use the same fuse that you removed in the circuit, for THAT circuit. The other fuse size will depend on what you add. For a 3 amp rated charger you need to use the next size up fuse. So a 5 amp is needed, and yes I know you can get a 3 but 5 is the common size that will come in any bulk fuse pack. A 5 will protect your circuit from either a spike, or short. If any one needs pics to understand the fuse tap then say and I'll show you how the tap actually powers 2 circuits.
  18. May 21, 2016 at 11:55 PM
    #58
    Ridgeline001
    Oregon
    2014 DCLB Sport 4wd
    Yes, you can safely use both of those circuits to the same tap. They are very low amp circuits, and are not likely to ever be used at the same time at max amp output for an extended time to even warm up. I recommend a 5 amp fuse.
    dblj70[QUOTED] likes this.
  19. May 22, 2016 at 5:54 AM
    #59
    dblj70
    Jeff
    Thank you sir.
  20. May 22, 2016 at 5:58 AM
    #60
    dblj70
    Jeff
    Thank you. My add a fuse currently has two 15A fuses in it. Are you suggesting that I change the one for the glovebox / usb to a 5A?
