Duck tape residue
Discussion in 'Detailing' started by d_lux137, Feb 26, 2019.
  1. Feb 26, 2019 at 1:04 PM
    d_lux137
    d_lux137 [OP] Active Member
    so my truck got broken into and i did the whole duck tape cardboard look until i got the window fixed. i ducked taped the outside against the vehicle paint instead on inside the cab (which probably would have been smarter)
    Now i have the duck tape residue on the paint and was wondering for anyone thats been through this, what is the best approach to remove said residue and not take the paint with it?
  2. Feb 26, 2019 at 1:11 PM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Easiest without damaging paint is use duct tape and press on area then pull. Repeat all the areas until you got it all then wax area.
  3. Feb 26, 2019 at 1:13 PM
    d_lux137
    thanks, ive heard its better to heat up the residue first by using a blow dryer. have any thoughts on that?
  4. Feb 26, 2019 at 1:15 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    100% pure acetone will break down the adhesive and not harm any clearcoat. You can pick it up at any auto parts store. Or if you wanna stay cheap and test it, then just steal some nail polish remover from the ol' lady, but it is not 100% though.
  5. Feb 26, 2019 at 1:20 PM
    d_lux137
    thank zipp
    zippsub9 likes this.
  6. Feb 26, 2019 at 1:23 PM
    NotRed
    NotRed Well-Known Member
    WD40 or goof-off
  7. Feb 26, 2019 at 1:28 PM
    d_lux137
    wd 40 works for this?
  8. Feb 26, 2019 at 5:45 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    Nunya Bizness likes this.
  9. Feb 26, 2019 at 6:25 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I would not recommend Acetone as it is a very "hot" solvent and will indeed damage clear coat. In fact it will damage just about any painted surface if left in contact with it.
  10. Feb 26, 2019 at 6:32 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    To each his own, never had a problem on Mercedes, Maseratis, Harleys or Porsche clear coat. My Tacoma debadging was not affected and been using it for years. It breaks down adhesives then evaporates, it doesn’t stay in contact longer than a minute before evaporating.
  11. Feb 26, 2019 at 6:41 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I 2nd the 3M adhesive remover.
  12. Feb 27, 2019 at 5:41 AM
    Too Stroked
    Tom
    I've seen / experienced two nasty fails with Acetone. One was on a clear coated aluminum F-150 wheel where a very short exposure destroyed the clear coat. The second was on a Dodge pickup where the owner tried to remove some adhesive from a Velcro secured tonneau cover on the tops of the bed rails. Went right through the clear and color coats, down to the primer. For me, that's two too many fails to even take a chance on it again.
  13. Feb 27, 2019 at 5:45 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Clay bar.
    If you try to scrub and scrape it off you will scratch/marr your paint.
    Never use acetone. It’s called the universal solvent for a reason.
    You can use isopropyl alcohol diluted 1:2 with warm water to clean up after the clay bar, but its likely not neccessary.
  14. Feb 27, 2019 at 5:48 AM
    PackCon
    Connor
    These are excellent suggestions if your goal is to convince people to irrepairibly damage their paint jobs.
  15. Feb 27, 2019 at 7:04 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Sorry to hear that, never had any problem on foreign vehicles or domestic motorcycles. The clear coat on wheels and frames is different as well. Some is baked on clear coat for aluminum utilizing a different adhesion process sometimes powder coated. All the exposures that I do are on a solid, undamaged, clear coat without any fading or breaches.
    Thanks, I try my best. Never happened for me and not here to ruin anything for anybody, but thanks for your insightful experience based additive response.
  16. Feb 27, 2019 at 7:07 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Me as well. Works great and is designed specifically to be used on automotive paint.
    NMTrailRider[QUOTED] likes this.
  17. Feb 27, 2019 at 7:09 AM
    qua77ro
    qua77ro Well-Known Member
    Socal
    '19 Taco TRD OR, '14 Cayman S, '10 S4
    Avoid acetone... it's too aggressive when there are better products like 3m professional adhesive remover. If you can't find that, soak liberally in Goo Gone or WD40. Do this when its warm preferably not cold
    Too Stroked likes this.
  18. Feb 27, 2019 at 7:23 AM
    PackCon
    Connor
    Acetone and nail polish remover are NOT paint safe. It doesn’t matter what your experiences are. If you know what acetone is that one is self explanatory.
    Its aggrevating to have people post potentially harmful advice on a detailing forum because they don’t know or don’t care about their vehicles paint job/finishes. Hence my comment.
    People post questions here because they do care and want educated direction on how to best care for their vehicles finishes. Especially given the rampant misinformation that exists.
    There is a cardinal rule in detailing that should always be followed:
    Use the least aggressive method first then slowly work up as needed.
    Acetone is not an appropriate suggestion in dealing with such a minor issue. Especially because you never even mentioned dilution. Its very uncommon to use undiluted chemicals in detailing.
  19. Feb 27, 2019 at 11:24 AM
    d_lux137
    Ok some mixed views on this but thanks everyone
  20. Feb 27, 2019 at 11:26 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    3M adhesive remover or try peeing on it!
