DUI WTF I wasnt driving
Discussion in 'Off-Topic Discussion' started by Jerry311SD, Aug 13, 2018.
Thread Status:
Not open for further replies.
  1. Aug 13, 2018 at 8:13 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Gas station should have CCTV. Hopefully it clearly shows your girlfriend getting out of driver seat.
    Gunshot-6A, Fiesta346 and Coot83 like this.
  2. Aug 13, 2018 at 8:14 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Per California's driving under the influence (DUI) laws, it's illegal to operate a motor vehicle with any of the following blood alcohol concentration (BAC) percentages:
    • 0.08% or higher― 21 years old or older operating a regular passenger vehicle.
    • 0.04% or higher―operating a commercial vehicle.
    • 0.01% or higher―younger than 21 years old.
    All states in the USA have a standard legal blood alcohol limit of .08, but most people probably don’t realize that you don’t have to blow a .08 on a breathalyzer to be convicted of DUI. Motorists with a lower blood alcohol content can be prosecuted and convicted if law enforcement can prove they were too drunk to drive when stopped.
  3. Aug 13, 2018 at 8:14 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I don't actually believe that link provided above is correct, as I understood it to be fairly well documented that the entire outcome of Miranda v. Arizona was that it became a requirement that police have to mirandize you, and you have to either implicitly or explicitly waive those rights, in order for any police questioning to be used as evidence in a trial. Although I do agree that obviously, any such evidence someone tries to use against you will be inadmissible.
    Since 'in custody' becomes a matter of semantics (read: how you lose court cases), most departments I'm familiar with err on the side of CYA and mirandize immediately.
    Either way, it's all kind of moot. Hopefully OP can get out of this bind.
  4. Aug 13, 2018 at 8:15 AM
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
    I know in some states, like Oklahoma, the 'Actual Physical Control' clause can allow them to arrest you. You were seen on the driver's side, key was in ignition, etc.etc.
    If you lawyer up you should be good though, just make sure you and your GF's stories are the same, LOL
  5. Aug 13, 2018 at 8:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Plenty of cases (regardless of the supposed crime) have been thrown out because cops didn't follow proper protocol. Not reading Miranda Rights is at the top of that list.
  6. Aug 13, 2018 at 8:19 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    We can armchair lawyer this all day long but it’s not going to change the fact the OP is in the situation he is in now. @JimBeam has the best advice yet, get a court appointed lawyer due to hardship and get his ducks in a row to fight it.
  7. Aug 13, 2018 at 8:23 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Lots of certified paralegals in here apparently. Probably best this thread goes away. It's not helping OP.
    Get a lawyer (public defender or otherwise) and stop talking about it publicly.
  8. Aug 13, 2018 at 8:24 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    First off, go get real legal advice. No one one here, no matter their background, is going to be able help you get off these charges if you’ve been charged. If you have the charges, and it sounds like you do, then you have been charged and should have a court date shortly. Representing yourself will not help. Launching a compliant may be a part of the actions you take, but in itself does not get those charges dropped. Ideally you, or someone you trust, has a good relationship with a law firm and can get you a free or cheap consultation on what your case would look like and what your odds are of winning given your story and the available evidence. That should be your first step. They will tell you what to do, ask lots of questions. In a perfect world it will never get to court and your law firm will get the charges dropped by pointing out the flaws in the states charges against you.
    Were you holding or in procession the keys when you opened the drivers door and reached into the vehicle? I know this sounds horrible but I know cases my wife has worked on where if you are holding they keys and inside the vehicle on the drivers side then you can be charged with DUI without actually driving the car, or even starting it. Basically the way the law is interpreted, in Canada anyways, is that if law enforcement can reasonably assume you were driving OR just about to drive you can be charged with a DUI. So if you were bent over looking like you might be getting into the vehicle while holding the keys odds are the officers arrested you because they felt you were likely the driver or about to drive. They don’t have to show you the number on the breathalyzer nor do they have to read you your rights when you are arrested. Like Jberry said, they only have to respect your rights. You will be able to get the number that was on the breathalyzer at both the road side test and the station test from the officers reports which will be available to your lawyer prior to going to court. It’s usually the station test that is trusted anyways, the road side test can usually be easily challanged by a good lawyer. Anyways depending on your situation that that’s a rundown of why you were likely arrested and why certain things you expected to happen didn’t happen. A good lawyer is you best bet in that situation.
    JustinL likes this.
  9. Aug 13, 2018 at 8:26 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Breathalyzers are soft with a decent lawyer. Hang in there buddy, it's a long process but you can do it. One day at a time
    Gunshot-6A likes this.
  10. Aug 13, 2018 at 8:26 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    You mean the Barracks School of Law / Google University aren't accredited institutions? :rolleyes:
    Definitely best to leave it to the people that get paid to do this sort of thing.
  11. Aug 13, 2018 at 8:27 AM
    GHOST SHIP
    GHOST
  12. Aug 13, 2018 at 8:31 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    At least OP didn’t rob a bank.
    Too soon?
  13. Aug 13, 2018 at 8:32 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I would just say it was your evil twin and he's on the lam.
    But for real... get a public defender OP. Tell him everything that happened. The WHOLE truth. Follow his advice and you'll make it through one way or another.
  14. Aug 13, 2018 at 8:33 AM
    GHOST SHIP
    GHOST
    :rofl::fistbump:
    Crow_of_judgement likes this.
  15. Aug 13, 2018 at 8:33 AM
    #35
    Jerry311SD
    Jerry311SD [OP] Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    We were on the side of the freeway, we were both out of the car and at the turnk when CHP pulled up behind us to (help us ) as he said.
    I wasnt yelling or talking back or anything rude like that .
  16. Aug 13, 2018 at 8:34 AM
    #36
    Comatose
    Miguel
    San Diego, CA
    ^ This. Completely factual.
  17. Aug 13, 2018 at 8:34 AM
    #37
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Soft at the road side, and hard to beat if he blew over at the station. As long as the calibration procedure is followed to a T on the breathalyzer that was used in the station. Almost all of the easy to win legal arguments about breathalyzer tests are based on the machine being contaminated or out of calibration due to road side use. The one at the station avoids all of those arguements. Blood tests are pretty much iron clad.
  18. Aug 13, 2018 at 8:34 AM
    #38
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Just like speed limits!! If your going the posted speed limit, then you are still legal right??
  19. Aug 13, 2018 at 8:35 AM
    #39
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Guarantee there's a large part of this story missing.
    whatstcp and SAB_0010 like this.
  20. Aug 13, 2018 at 8:35 AM
    #40
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I think as others have stated...get a lawyer started on this and see if he/she can get footage of the gas station. It might really help identify the night that your gf was indeed your DD and you were simply getting something out of the back. Regardless, this is a learning situation for all of us in the future should you need to get anything from a vehicle that you have a DD for already.
Thread Status:
