Dull Interior Lighting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Firefighter160, Jan 18, 2011.
  1. Jan 18, 2011 at 4:16 PM
    Firefighter160
    Firefighter160 [OP] Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Im getting really tired of the poor lighting in my truck. Is there a better bulb to use, also my truck is an extra cab so the light is in the center of the ceiling but I notice if I pull the cover off where my rear view mirror is (where the light is in a regular cab is) it looks like you could easliy put in socket and bulb there. Has any one tried this?
  2. Jan 18, 2011 at 4:20 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    subbed
  3. Jan 18, 2011 at 7:55 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    Any body......
  4. Jan 18, 2011 at 8:02 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    you can upgrade to LED bulbs, should help a bit. As far as the maplight, I added one from from the newer first gen into my truck(didnt have one).
  5. Jan 18, 2011 at 8:04 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  6. Jan 19, 2011 at 3:15 AM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    The domelight LEDs are great..... as long as the truck has power turned on. Without power you get FAR less light than with a standard bulb, its more like a faint flicker.
  7. Jan 19, 2011 at 3:37 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Got some LEDs for mine from Superbright LEDs.com
  8. Jan 19, 2011 at 1:45 PM
    Flash1034
    Flash1034 Well-Known Member
    Southern California
    2003 SR5 TRD 4x4 Extracab 3.4 liter
    None
    What kind of interior light bulb does an 03 extracab have?
    Thanks,
    Flash
  9. Jan 19, 2011 at 5:16 PM
    Poppintool
    Poppintool BAMF
    Tim
    Arizona
    04 PreRunner SR5 TRD
    LED Interior
    The regular bulb type is DE3175. If you are shopping on superbrightleds.com then the LED bulb equivalent is 3022. I just bought three of the exact same kind for my interior. The dome and both map lights all take the same bulb. Here's a direct link to useable bulbs for your year:
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Ffestoon.html
    I chose the cool white LED Festoon Bulbs (not the high power ones, the ones that look strangely like lego pieces). Click on the 3022 tab. I recommend the 3022 x9 since you get more LEDs. My friend has the same type in his '07. They look great!
  10. Jan 19, 2011 at 5:20 PM
    Poppintool
    Poppintool BAMF
    Tim
    Arizona
    LED Interior
    See my post above if you're still looking. These bulbs will work on yours too.
  11. Jan 19, 2011 at 5:29 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Is this true with all LED's? If so, that sucks. The only time I need lots of light is when the truck is off and I'm leaning in to find something.
  12. Jan 19, 2011 at 5:50 PM
    Poppintool
    Poppintool BAMF
    Tim
    Arizona
    LED Interior
    No this isn't true of all of them. I haven't had this issue, nor has my friend. Maybe using the high power ones draws more power which causes them to be dull. The ones we use didn't have that problem and the thread (which I'll have to find) that I originally found the mod on didn't report that problem either.
  13. Jan 19, 2011 at 5:52 PM
    NegroTundra
    Land of Enchantment
    ^Cool thanks, guess I'll give this LED thing a chance now.
    If I could just figure out how to tie my map lights in with my dome light (all lights on when door open), I would be soooo happy!
  14. Jan 20, 2011 at 8:41 PM
    javadoody
    javadoody Active Member
