Dumb dude messed up his transmission, seeking advice!
Discussion in 'Technical Chat' started by Spalo, Nov 1, 2012.
  1. Nov 5, 2012 at 10:10 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    When you feel like an idiot, look at Krazie's thread. If anyone could link this gentleman to that thread, that'd be great. My computer has gone full retard right now, or I'd find it myself.
  2. Nov 5, 2012 at 10:11 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Hate to hear that happened :( If it were me I'd just continue to drive it, but I'd be putting away some money for a new tranny in the future. If the tranny ends up being okay, your new tranny money then becomes mod money :D
  3. Nov 5, 2012 at 10:13 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    At least you didn't put the tranny fluid in with your coolant :eek:
    HALP!
  4. Nov 5, 2012 at 10:16 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
  5. Nov 6, 2012 at 7:48 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I am amazed its gone this far without seizing up, fuck it, drive it until it breaks is the way I look at it. No need to fix something that works.
  6. Nov 9, 2012 at 5:08 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Some guys make better woman
  7. Nov 10, 2012 at 9:04 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That ^ was competly uncalled for. :mad:
  8. Nov 10, 2012 at 9:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  9. Nov 10, 2012 at 9:11 PM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I was just about to ask if someone else had done something like this already lol, here it is
  10. Nov 10, 2012 at 9:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Why didn't you check the engine oil level after adding oil? :p
  11. Nov 10, 2012 at 9:42 PM
    kamehameha
    kamehameha Well-Known Member
    Nick
    Chicago
    08 Double Cab SR5
    LED interior lighting-DRL mod-Tinted windows 20%front Limo rear-K&N CAI-3inch leveling kit-Factory Auto Dimming Mirror Upgrade Pioneer Double Din DVD/Radio-
    the transmission fluid level is supposed to be checked at a specific temperature see procedure that follows. if a random shop did the fluid exchange it may not have been done properly.
    Last Modified: 9-26-2012 6.4 N From: 200708
    Model Year: 2008 Model: Tacoma Doc ID: RM0000017CO002X
    Title: A750F AUTOMATIC TRANSMISSION: AUTOMATIC TRANSMISSION FLUID: ADJUSTMENT (2008 Tacoma)
    ADJUSTMENT
    1. BEFORE REFILL TRANSMISSION
    This transmission requires Toyota Genuine ATF WS.
    It is necessary to refill the transmission with the correct amount of fluid.
    The vehicle must remain level while adjusting the transmission fluid level.
    On vehicles equipped with active suspension, turn the suspension control switch OFF if it is necessary to jack up the vehicle with the engine running.
    2. TRANSMISSION PAN FILL
    (a) Remove the refill plug and overflow plug.
    (b) Fill the transmission through the refill hole until fluid begins to trickle out of the overflow tube.
    (c) Reinstall the overflow plug.
    3. TRANSMISSION FILL
    (a) Fill the transmission with the correct amount of fluid as listed in the table below.
    (b) Reinstall the refill plug to avoid fluid splash.
    REPAIR
    FILL AMOUNT
    Transmission pan and drain plug removal
    1.7 liters (1.8 US qts, 1.5 Imp. qts)
    Transmission valve body removal
    4.3 liters (4.5 US qts, 3.8 Imp. qts)
    Torque converter removal
    5.4 liters (5.7 US qts, 4.8 Imp. qts)
    HINT:
    If you cannot add the listed amount of fluid, do the following:
    Install the refill plug.
    Allow the engine to idle with the air conditioning OFF.
    Move the shift lever through entire gear range to circulate fluid.
    Wait for 30 seconds with the engine idling.
    Stop the engine.
    Remove the refill plug and add fluid.
    Reinstall the refill plug.
    4. FLUID CIRCULATION
    (a) Allow the engine to idle with the air conditioning OFF.
    (b) Move the shift lever through entire gear range to circulate fluid.
    5. FLUID TEMPERATURE CHECK
    NOTICE:
    The fluid temperature can be confirmed by checking the indicator light in the meter or by using the Techstream. When using the Techstream, it is necessary to change to temperature detection mode in order to idle the vehicle appropriately.
    (a) When using the Techstream:
    (1) Turn the ignition switch OFF.
    (2) Connect the Techstream to the DLC3.
    (3) Turn the ignition switch ON.
    (4) Enter the following menus: Powertrain / Engine and ECT / Active Test / Connect the TC and TE1.
    (5) Enter the following menus: Powertrain / ECT / Data List / A/T Oil Temperature 1.
    (6) Check ATF temperature.
    NOTICE:
    If the fluid temperature is below 46°C (115°F), proceed to the next step. (Recommended ATF temperature: 36°C (97°F) or less.)
    If the fluid temperature is 46°C (115°F) or more, turn the ignition switch OFF and wait until the fluid temperature drops below 46°C (115°F).
    (7) According to the display on the Techstream, perform the Active Test "Connect the TC and TE1".
    HINT:
    Indicator lights of the combination meter blink to output DTCs when TC and TE1 are connected.
    (8) Start the engine.
    NOTICE:
    Check that electrical systems such as the air conditioning system, audio system and lighting system are off.
    (b) When not using the Techstream (using indicator light):
    (1) Using SST, connect terminals 13 (TC) and 4 (CG) of the DLC3.
    SST: 09843-18040
    (2) Start the engine.
    NOTICE:
    HINT:
    Indicator lights of the meter blink to output DTCs when terminals TC and CG are connected.
    (c) Slowly move the shift lever from P to L, and then return the shift lever to P.
    HINT:
    Slowly move the shift lever to circulate the fluid through each part of the transmission.
    (d) Move the shift lever to D, and quickly move back and forth between N and D (once within 1.5 seconds) for at least 6 seconds. This will activate the fluid temperature detection mode.
    Standard condition:
    A/T OIL TEMP warning light remains illuminated for 2 seconds and then turns off.
    (e) When using the Techstream:
    (1) Return the shift lever to P and press OFF on the Active Test display.
    (f) When not using the Techstream:
    (1) Return the shift lever to P and disconnect terminals 13 (TC) and 4 (CG).
    (g) Allow the engine to idle until the fluid temperature reaches 36 to 46°C (97 to 115°F).
    (h) The A/T OIL TEMP warning light will come on again when the fluid temperature reaches 36°C (97°F) and will blink when it exceeds 46°C (115°F).
    Indicator Indication of ATF Temperature:
    BELOW PROPER TEMPERATURE
    PROPER TEMPERATURE
    HIGHER THAN PROPER TEMPERATURE
    Data List: [A/T Oil Temperature 1]
    36°C (97°F) or less
    46°C (115°F) or higher
    A/T OIL TEMP warning light:
    Turn off
    Turn on
    Blinking
    NOTICE:
    Perform the fluid level inspection while the indicator light is on.
    6. FLUID LEVEL CHECK
    NOTICE:
    The fluid temperature must be between 36°C (97°F) and 46°C (115°F) to accurately check the fluid level.
    (a) Remove the overflow plug with the engine idling.
    (b) Check that the fluid comes out of the overflow tube.
    If fluid does not come out, proceed to step 7.
    If fluid comes out, wait until the overflow slows to a trickle and proceed to step 8.
    7. TRANSMISSION REFILL
    (a) Install the overflow plug.
    (b) Stop the engine.
    (c) Remove the refill plug.
    (d) Add 0.4 liters (0.42 US qts, 0.35 Imp qts) of fluid.
    (e) Allow the engine to idle and wait for 10 seconds.
    (f) Proceed to step 6.
    8. COMPLETE
    (a) Install the overflow plug with a new gasket.
    (c) Install the refill plug with a new gasket.
    Torque: 20 N·m (205 kgf·cm, 15ft·lbf)for overflow plug
    Torque: 39 N·m (400 kgf·cm, 29ft·lbf)for refill plug
  12. Nov 19, 2012 at 9:33 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    drunken posting, must have been the wrong thread with multiple windows open
  13. Aug 1, 2013 at 1:37 PM
    Smardt Turbocor
    Smardt Turbocor Older Guy
    Galen
    Lexington South Carolina
    Tacoma 1/2 cab 4.6 Liter V-6 5 speed manual
    No criticism here,
    First, if you drove the automatic without fluid there is damage, to clutch plates which probably have slipped and burnt, friction bands, whatever, or if motor oil was in it.
    If you put motor oil in the automatic, whether you have already done it or not, you would have to get all of it out by 100% flushing or something equivalent.
    Even if you didn't, they could be debris, which flushing would help get rid of.
    On American cars you change the throwaway transmission filter for sure at the same time; at least once if not twice. (You are trying to save the automatic) many Jap cars just have screens. (Ask a transmission shop what to do)
    Some car manufacturers are very fussy about the fluid they like. For example Honda's are famous at torque converter lock up shudder if you use "generic" transmission fluid. I had that issue on a perfectly overhauled Honda that used an "equivalent additive". I changed to Honda fluid, and it began shifting and locking up perfectly.
    The reason I mention that is that clutches and bands tend to absorb the fluid they run in. I think you see where I am going: incompatibilities...gooeyness, that sort of thing. If there is no motor oil in the automatic, then we are just worried about no lubrication damage.
    So for now, not knowing much, I would put in genuine Toyota fluid after flushing, for now. I know the Camrys can take generic fluid. Maybe yours can too. Just check with Toyota or your local transmission shop.
    Other than that, cross your fingers, and start saving in case the automatic goes out.
    Good Luck
  14. Aug 6, 2013 at 2:12 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    This is 3rd or 4th thread I have read concerning this issue. Do not feel stupid. Again as mentioned the trany was not empty, so how knows. Good luck and stick with Tacoma World.:)
