Dumb idea to lift a base model Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bayareaTRD, Mar 19, 2012.
  1. Mar 19, 2012 at 1:20 AM
    bayareaTRD
    bayareaTRD [OP] New Member
    Bay Area, CA
    1998 Tacoma
    Been looking for a 4x4 or per runner 1st gen, but ended up getting a base model xtra cab for a price I couldn't pass up.. So would it be a stupid thing to do to put a lift kit on my Tacoma? Has anyone done this to a regular Tacoma before? I didn't plan on using the 4x4 anyway, just like the looks of them...
  2. Mar 19, 2012 at 1:23 AM
    bhh2000
    bhh2000 Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    its possible, guys on here have done it. I would like to know my self because around here the prise difference is at least 2K for the 5lugs VS a prerunner so if I could lift them and sell them it would be awesome. could someone explain what makes them so different?
  3. Mar 19, 2012 at 1:39 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  4. Mar 19, 2012 at 1:42 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm sure someone will want to buy your 4x4parts if you don't want/need it
  5. Mar 19, 2012 at 2:10 AM
    blacksheff405
    blacksheff405 no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    someone has 4x4 parts for sale?? :spy:
    mahaloTaco likes this.
  6. Mar 19, 2012 at 2:31 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    yes
  7. Mar 19, 2012 at 7:46 AM
    bayareaTRD
    Bay Area, CA
    1998 Tacoma
    i'm guessing 5lug is the base model tacoma? and 6lug would be pre runner and 4x4? this is my first tacoma, so i wouldnt know..
  8. Mar 19, 2012 at 7:51 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    It's a stupid idea to build your truck based on other people's opinions of what looks good, what doesn't, what's a good idea, what isn't, etc.
    Firebird likes this.
  9. Mar 19, 2012 at 10:05 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Dont lift a 5 lug
  10. Mar 19, 2012 at 10:10 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    X2.
    Do whatever the hell you want with it. It's your truck. I've seen some sick looking 5 luggers.
  11. Mar 19, 2012 at 3:14 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    if you are lifting a 5 lug might as well get a sick mid-travel set up
  12. Mar 19, 2012 at 5:46 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    X2...
    mid travel that BITCH!!!
    Or just runs spindles and an AAL or a shacke in the rear and run some aggressive 31'' tires.
    IMO it would look good...do what you think would look good, not what others think...
    but PLEASE do the lift right...do not run spacers or blocks!
  13. Mar 19, 2012 at 6:40 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Why not lift it?
    What is with all of you saying not to lift a 5 lug? By that logic you shouldn't lift a prerunner either then. What is the difference between a 5 lug and a prerunner? Suspension, engine, and an extra lug. Maybe even gears. I could see the no way comments if he wanted to slam a 4x4, but that isn't the case.
    If you want to lift it then do it, just be sure to be thorough in your research.
  14. Apr 4, 2012 at 6:08 PM
    shampoop
    southwest WA
    Some people believe exactly that. I'd take a 5 lug truck over a pre-runner for sure. From an objective point of view (excluding styling preferences) the pre-runner really serves no purpose. 5 lug trucks have lots of advantages over 4x4's in many areas, 4x4's also have many advantages over 5 luggers. Pre runners have the worst features of each group. (other than brakes, i'm assuming 5 lugs don't have the fixed 4 piston calipers).
  15. Apr 4, 2012 at 6:18 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Lift it! I did and was able to put much bigger A/T tires which make all the difference in the world when in off road or wintery conditions. Every person here that has a 4x4 will tell you not to do it, not sure why or care to know why. Do what ever you want, it's your truck! :)
  16. Apr 4, 2012 at 6:19 PM
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    I would do it.
  17. Apr 4, 2012 at 6:40 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    I say do it. I've seen some pretty sweet lookin 5-luggers. Idk what your planning on using it for but you can't go wrong with having your truck the way you want it :D
  18. Apr 4, 2012 at 6:50 PM
    rabbit209
    rabbit209 Member
    mike
    rochester ny
    99 taco 6 in lift 5.29 front and rear
    a ton
    I would do it!! Mine is a base model except for the 4x4 part.
