dumb manual transmission question starting on a hill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squirrelNUts, Apr 2, 2010.
  1. Apr 2, 2010 at 8:52 PM
    squirrelNUts
    squirrelNUts [OP] Active Member
    Ted
    Massachusetts
    This is my first standard transmission vehicle. I've driven friends manual cars sometimes, but now that it's my truck i'm in a whole new learning curve. I'm fine except for starting from a dead stop on a hill (ie at a stop light uphill). Any tips/ good reading on learning to drive standard welcome! I either burn out, stall, or buck. I'm sure the answer is just practice, but what do you do in this situation? How do you go from clutch in and brake in to moving forward smoothly? Do you roll back some, if so, how much?
    Thanks,
    Ted
  2. Apr 2, 2010 at 8:57 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    just gotta learn to be quick on the pedals, and let the clutch slip a bit before you fully let off the clutch pedal. helps to rev the engine a little higher than you normally would.
    most importantly, dont worry about the goofball behind you right on your bumper, if you roll back and hit him, its his fault for not leaving enough space
  3. Apr 2, 2010 at 9:01 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I keep right foot on brake and let out the clutch just enough until it engages. You'll hear the truck's idle change and feel it. At that point I switch the right foot over to the gas and go.
    If I don't do that it's normal to roll back a a few inches or so.
  4. Apr 2, 2010 at 9:02 PM
    squirrelNUts
    Ted
    Massachusetts
    if they're not an inch from the bumper, they're closer! I'm afraid of rolling back. I had 60 miles on the truck and got pulled over for "showing off" when I peeled out a bit 'cause I was nervous about rolling into the car behind me. He was nice and told me to get some practice! I'm getting better, but just need some experience I'm sure!
    Ted
  5. Apr 2, 2010 at 9:05 PM
    squirrelNUts
    Ted
    Massachusetts
    My clutch doesnt' catch until all the way out...is that typical? I know some sports cars that engage just off the floor. I assume all clutch pedals are different. I keep moving my seat back because I have a tendency to rev it too much and not let the clutch out enough on hills!
    Ted
  6. Apr 2, 2010 at 9:10 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    what i do usually is i let the clutch out almost all the way staying on the break til it starts to grab a little so im not rollling forward and im not rolling back, then just give it gas and slowly let it out the rest of the way.
  7. Apr 2, 2010 at 9:11 PM
    squirrelNUts
    Ted
    Massachusetts
    that's what I seem to do!
    edit: schiz: that's not you in your picture I'm sure!
  8. Apr 2, 2010 at 9:22 PM
    squirrelNUts
    Ted
    Massachusetts
    hard to practice in boston traffic...i've got to find a quiet hill to get some laps in!
  9. Apr 2, 2010 at 9:29 PM
    squirrelNUts
    Ted
    Massachusetts
    and had fewer problems, probably because I was in 4lo and also didn't have to worry about the 100K mercedes behind me in traffic!
  10. Apr 2, 2010 at 9:34 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    X2
  11. Apr 2, 2010 at 9:36 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    Practice....and the e brake for well emergencies :p
  12. Apr 2, 2010 at 10:13 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    very good advice and wording here. let the clutch out till it grabs two revs then go.
  13. Apr 3, 2010 at 9:59 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I used to frequently use that "blip the gas" method in all other vehicles. But I've found it doesn't work quite as well in the Tacoma with the dumbass computer controlled throttle.
    I don't really have any problems with rolling back, but actually off hand, I can't even say what I typically do without doing it. I'll have to pay attention next time.
  14. Apr 3, 2010 at 7:50 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    If firsr gear was a decent low gear then starting on a hill wouldn't be all that hard but since it's a tall gear you gotta give it a little throttle and slip the clutch a little. It does take practice and and ya gotta pay attention to task at hand and not the split tail with the short skirt sittin next to ya:)
  15. Apr 3, 2010 at 7:59 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Use your e brake.
    Engage it and slowly let it out as you work the clutch and gas.
  16. Feb 13, 2012 at 8:10 AM
    ohmyitstrucktime
    ohmyitstrucktime Active Member
    Calgary
    trd
    I"ve always just used my e brake on past standards... I just picked up my taco 6spd. Was suprised, pretty nice!...(the manual) but ya i guess i'll just continue to use my ebrake and when i feel a slight pull i'll let it out. Isn't this okay? i've alwas done this in the past. Just want to know that im not hurting the new beast. Cheers everyone
  17. Feb 13, 2012 at 8:14 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I usually use the car behind me to help out.
    Just slowly, and I mean slowly, let your truck rest against the car behind you. Once you feel that your truck isn't moving with your foot off the brake you're ready to start the climb.
    Hope this helps.
  18. Feb 13, 2012 at 8:20 AM
    Jdevine80
    Jdevine80 Member
    Josh
    Fort Collins, CO
    '11 V6 DC TRD Sport 6 Speed
    Are you serious? I would go nuts if I saw someone doing this to my vehicle. Use the e-brake as the previous poster said. It's simple that way.
  19. Feb 13, 2012 at 8:25 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    How is that done w/a e-brake pedal? (I don't have a manual Taco.) Are they both close enough that they can be released at the same time w/the left foot? I do this trick in my car but it has an e-brake lever so it's easy enough for any noob to do.
  20. Feb 13, 2012 at 8:26 AM
    Jdevine80
    Jdevine80 Member
    Josh
    Fort Collins, CO
    The e-brake is a hand brake. Feet for the clutch and gas, hand on the brake.
