Dumb newb wheel and tire question
Discussion in '5 Lug' started by YodasYota, Oct 27, 2011.
  1. Oct 27, 2011 at 12:05 PM
    YodasYota
    YodasYota [OP] I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, 300mm Broadway rear view mirror, LED brake lights, side markers, rear turn signals, plate lights, and interior lights. Flowmaster cat back exhaust, a cracked tail light that I fixed with some tape, all black grille, 15” Raceline 401B wheels, Goodyear 235/75/15 All Terrain Tires
    Sooooo I have a 2005 2.7 5lug did the "black box mod" now debating on wheels and tires. I'm Pretty set on black pro comp 15x8 steels and general grabber 30x9.5r15. I guess my quistion is that pro comp also has the same thing in alloy wheels was wondering what the losses and gains might be. Thanks:confused:
  2. Oct 27, 2011 at 12:09 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    whats this black box mod?
  3. Oct 27, 2011 at 1:49 PM
    YodasYota
    Yoda
    White 2005 2.7L
    On the 2nd gen 2.7 5lug in the front wheel wells is a black box bolted on behind the plastic liner. It restricts being able to put a 30x9.5 tire I believe with the box mounted you can run up to 235x75r15. So it's just to run bigger tires. In order to remove the black box I just took a razor blade and cut around the liner and unbolted it.
  4. Oct 27, 2011 at 5:22 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    the steelies and alloys might have a weight difference. id look into that first the lighter the better. good luck :thumbsup:
    oh and btw...:worthless:
  5. Oct 27, 2011 at 11:56 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    gearing will make a world a difference if you go bigger then 31s btw.
    but if 30s..you should be fine
