Dumb oil change question....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by All Beef Taco, Apr 7, 2010.
  1. Apr 7, 2010 at 8:35 PM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    So I changed my own oil for the first time today and everything went okay, or so I thought. Looking back on it, I realized that I didn't remove the old drain plug gasket. I did put a new one on the bolt and must have left the old one in place stuck to the bottom of the engine. Nothing is leaking... will it be okay to just leave the two gaskets in place until my next oil change?
  2. Apr 7, 2010 at 8:40 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    Yes. As long as it's tight.
  3. Apr 7, 2010 at 8:40 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    If you're torqued right you should be ok.
  4. Apr 7, 2010 at 8:42 PM
    Przemekmsu
    Przemekmsu Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    You should be fine, just check for any leaks once in a while just to be sure.
  5. Apr 7, 2010 at 8:42 PM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    :cool:it ok!! just check it in a few day!! But it should be fine!!! I change my gasket about once a year. Did you change your air filter?
  6. Apr 7, 2010 at 9:09 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    You're probably alright, just make sure you don't do the same on the oil filter-that usually makes a wild mess.
  7. Apr 7, 2010 at 9:21 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Did that one before on my honda :facepalm: my driveway still bares the mark of my mistake
  8. Apr 7, 2010 at 9:31 PM
    All Beef Taco
    Joe
    Thornton, CO
    Cool, thanks for all the input, fellas!
  9. Apr 7, 2010 at 9:49 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I have used the same gasket 3 times now, no leaks... yet... :)
  10. Apr 7, 2010 at 10:35 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    My gasket always sticks to the oilpan.
