Dumb question about cabin air filter and glove compartment strut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blacksheep515, Oct 18, 2012.
  1. Oct 18, 2012 at 6:28 PM
    blacksheep515
    blacksheep515 [OP] Active Member
    Ok, I turned the heat on today. It was 40 degrees outside. My truck started to smell all moldy, musty like a smoky bar. I couldn't stand it. So, I went to autozone and picked up a STP cabin air filter.
    I used the owners manual for the install. I opened the glovebox and the first thing I noticed was the stopper was just laying there attached to the bottom retainer the user manual says to detach. For the life of me I cannot figure out where the top attaches to...I saw a notch and tried to slide it on, but it will not stay on. Am I missing a piece that holds it on or something? Anyone have a picture? The strut has 2 holes and neither attaches to the top due to the dash being in the way? What am I doing wrong?
    I gave up and decided to replace the filter...
    I took filter out and see the toyota filter was facing arrow up and forwards. I took it out and noticed leaves and several twigs etc on the top.
    The STP filter has an air flow down arrow. I assume air comes from the top, hence the junk on it and installed it with the arrow facing down. Is this correct?
    Sorry for the n00b questions. :eek: All help appreciated!
    Thanks!
  2. Oct 18, 2012 at 6:53 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You installed the filter correctly, air flow is from the top down.
    The damper strut mounts by the two holes onto the two little plastic pins, but usually falls off one side in short order. I saw a mod somewhere ( here on tacoworld I think) where the guy put a small screw in the split in the plasic pin to hold it spread apart, which keeps the strut from falling off. Try searching, see what you come up with.
  3. Oct 18, 2012 at 6:59 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    That thing is an overengineered piece of crap. My friend and I spent hours going through the dash and tightening screws because we heard a rattling only to find out that it was that dampener. I was so pissed when I figured that out.
    Edit: We spent so much time doing that because we spent the day before putting a full layer of CDL tiles and CCF to get rid of any out side noise's and rattles.
  4. Oct 18, 2012 at 10:38 PM
    Saskamoose
    Saskamoose Active Member
    Christian
    Saskatoon, SK, Canada
    06 trd o/r 4x4 Access 4.0
    Borla Exhaust/Air Filter, Remote Start/Keyless Entry
    I had the same issue with that crappy dampener when I changed my cabin air filter. I pissed around with it for about 45 minutes before chucking it in my bucket of old auto parts that will never see the light of day again. I haven't missed that thing at all.
  5. Oct 18, 2012 at 11:01 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Anybody got a pic of this? I'm doing mine this weekend.
  6. Oct 18, 2012 at 11:03 PM
    Warhorseforever
    Will
    Sand Lapper
  7. Oct 18, 2012 at 11:09 PM
    badger
    badger Well-Known Member
    07 SR5
    after a few trips in and out of there for various mods and wiring, my damper started coming off the peg too. I just tossed it
  8. Oct 19, 2012 at 4:12 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I never knew I was supposed to have a glove box strut, I'm going to have to look and see if I have one or if it's disconnected. I know when I open the box it just flips open, no delayed action or anything like that. Did all 05 and up's have this?
  9. Oct 19, 2012 at 4:50 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I may go out and try to put that thing on again after reading that post. I could never get it to stay in place either.
  10. Oct 19, 2012 at 5:01 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    In this link if you attach the upper part B first, just stick a small screw in between the two tabs and that will hold it in (on mine at least that was the loosest of the two connection points). Leave the bottom A to snap in and out as is, so you can access the air filter still.
    Edit: same thing was said a few posts down in that thread...
  11. Oct 19, 2012 at 5:23 AM
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    i wonder if that's what's making the noise i keep hearing. plus it's about time to change my filter too, so I'll check it out this weekend.
  12. Oct 19, 2012 at 6:01 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Yes, all 05+ has it :)
  13. Oct 19, 2012 at 6:27 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    mine doesnt stay either just too lazy to toss is yet
  14. Oct 19, 2012 at 6:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Can't remember which end it was...but I put a big screw (wide head) between the plastic prongs, this keeps the thing ON. I disconnect it at the opposite end....which has been working (and staying on).
    I change/clean my filter yearly.
  15. Oct 19, 2012 at 8:05 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Spray the filter with a little air freshened or water and alcohol and run it, freshens the truck right up.
  16. Oct 19, 2012 at 10:58 AM
    tacowestley
    tacowestley Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    My strut came off too so i put a little super glue and voila, hasnt fell off since
