Dumb Question About ECGS
Discussion in 'Suspension' started by alimjr, Aug 13, 2018.
  1. Aug 13, 2018 at 10:30 AM
    alimjr
    alimjr [OP] Well-Known Member
    Almar
    Southern California
    2018 Magnetic Grey Tacoma TRD Sport
    -TRD Pro Grill -TRD Shift Knob -OEM Side Steps -BakFlip MX4 -FN FX Pro Wheels -Toyo OpenCountry AT2 265/70/17
    Hi guys. Dumb question here...is the ECGS only for 4WD Tacos?
  2. Aug 13, 2018 at 10:31 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
  3. Aug 13, 2018 at 10:32 AM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    Dont feel bad, I almost asked that many times but eventually deduced the answer
  4. Aug 13, 2018 at 10:37 AM
    alimjr
    Almar
    Southern California
    Well I feel like a fucking idiot. Took my truck to the shop to get it swapped out only to find out the bad news. I’ve been trying to get rid of vibrations after my lift.
  5. Aug 13, 2018 at 11:21 AM
    DLRIII
    David
    Baton Rouge
    Damn, that sucks. What did you install to get the lift?
  6. Aug 13, 2018 at 11:30 AM
    alimjr
    Almar
    Southern California
    I installed 5100s all around with OME 884 springs in the front. Have 1.5 inch blocks to lift the rear. I’m going to try some shims but if that doesn’t work I’m considering bringing it back to stock height. Love the look of my truck lifted but I’d rather have the truck function correctly over looks.
  7. Aug 13, 2018 at 11:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What kind of vibes are you getting?
  8. Aug 13, 2018 at 11:32 AM
    DLRIII
    David
    Baton Rouge
    I hear you on that man. I'm gonna lift my truck this fall, hoping I dont have vibrations. If I do, I'll figure out how to fix them though. 4x2 here as well
  9. Aug 13, 2018 at 11:34 AM
    alimjr
    Almar
    Southern California
    Im getting a rumble strip kind of vibe on acceleration and deceleration at 20mph. After I pass 20mph it’s gone and the truck rides great.
  10. Aug 13, 2018 at 11:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are the blocks installed correctly? Some blocks have the shims built into them, and when putting them backwards, it really fucks with the angles.
  11. Aug 13, 2018 at 11:35 AM
    alimjr
    Almar
    Southern California
    What sucks is in my quest to fix this I unknowingly bought the ECGS, just took it to a shop, just to find out it’s for 4WD. Feel like a complete idiot. They suggested trying UCAs but my alignment after lift met all specs.
  12. Aug 13, 2018 at 11:36 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    willing to bet that the vibration is from your drive shaft. Did you get a carrier bearing drop/spacer kit?
  13. Aug 13, 2018 at 11:37 AM
    alimjr
    Almar
    Southern California
    My blocks were flat. They start with an angle above 2 inches. I have the Icon AAL too. Planning on getting rid of the blocks adding the AAL and shims. Praying that gets rid of it.
  14. Aug 13, 2018 at 11:37 AM
    alimjr
    Almar
    Southern California
    Yes I did. Installed and it’s the same.
  15. Aug 13, 2018 at 11:37 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Sell it to me?
  16. Aug 13, 2018 at 11:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're on the right path. The shims should take care of the vibes. If not, you can get some washers and space the center support bearing of your driveshaft down a little bit. Sometimes it just takes some trial and error to get the angles just right.
    alimjr[QUOTED][OP] likes this.
  17. Aug 13, 2018 at 11:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh and just as an FYI, ECGS stands for East Coast Gear Supply. They're an awesome company for anything gears related. They make a bushing specifically for tacomas that replaces the front drivers side needle bearing in the diff. So people just commonly refer to it as the ECGS bushing.
    alimjr[OP] likes this.
  18. Aug 13, 2018 at 11:40 AM
    alimjr
    Almar
    Southern California
    I just want to get my money back. I have the removal tool as well. It was $105 total. I can ship it to you for $115? Let me know. Otherwise I’m waiting on a return authorization from ECGS
  19. Aug 13, 2018 at 11:40 AM
    TireFire
    Olympic Peninsula
    Best way is to tie a string on the axle tube and trans output shaft. Then you can see what's misaligned and I bet it's the pinion angle so dropping the drive shaft center is rarely the answer
  20. Aug 13, 2018 at 11:41 AM
    TireFire
    Olympic Peninsula
    No thanks lol I don't need the tools, just the bushing. Go ahead and return it if you still can
