Dumb Question about Tire Pressure
Discussion in 'Wheels & Tires' started by RBaptist, Dec 23, 2008.
  1. Dec 23, 2008 at 12:05 PM
    RBaptist
    RBaptist [OP] Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    The tires on my Tacoma say MAX Pressure 51 PSI. Is this the cold pressure that I am supposed to keep them inflated to? Or is something like 42PSI a good balance between hot and cold running conditions and load factor?
    As a side... 51 PSI sounded really high to me....I had the tires rotated and balanced a month ago and supposedly they checked the pressure. When I checked it today they were at 30PSI. I caught it because my pressure light came on (it was the spare).
    Anyway....I know it is a simple question...I just wanted to check.
  2. Dec 23, 2008 at 12:08 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Theres a sticker either on the driver door or on the b-pillar, open your dorr and look for it, It tells you what your tires should be inflated too, the psi on the tire itself is the tire manufacturer's max pressure for that tire
  3. Dec 23, 2008 at 11:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Never ever air up your tires to the max pressure, you're just asking for a blowout on the highway. Agreed with the above statement, look at the driver's door jamb and there should be a sticker telling you how many PSI is recommended.
  4. Dec 24, 2008 at 3:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never go by the max pressure listed on the tire..... that's for the TIRE only and what it can handle.
    Each vehicle has its own tire pressure recommendation - and that's based on a lot of variables of that paticular vehicle. Not only that - but you want even tire wear. I have an 07 Access Cab TRD Sport and my door jam says 29psi and I'm probably running closer to 33-34lbs.
    If you ran your tires too high - your tires would wear out in the center a lot faster and your kidneys would need replaced.
  5. Dec 24, 2008 at 5:15 AM
    RBaptist
    Newnan, Ga
    Thanks all.
    I figured that would be too high. I just wasn't sure if the sticker in the door only applied to a factory set. I am currently running at 34.
    Merry Christmas!
  6. Dec 24, 2008 at 5:26 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  7. Dec 24, 2008 at 5:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    ^^^^^X2.
  8. Dec 24, 2008 at 5:36 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    If you have the 265/70/R16 tires, front tires are 29 psi and the rear are 32 psi.
  9. Dec 24, 2008 at 5:49 AM
    Janster
    Jandy
    Lancaster, PA
    :thumbsup:
    When you guys change tires sizes & rim widths, the tire pressure changes also.
    Say for instance - you have a 33x12.50 on an 8" wide rim versus that same tire size on a 10" rim, the tire pressure will be different between the two.
    That's why the chalk test is a good way to determine what pressure you need for even tire wear.
  10. Dec 29, 2008 at 10:01 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    Depends on the weight your carrying. I frequently run 51psi in the rear. Your tires will NEVER blow out from running max psi, The lower the psi the higher the heat buildup in the tire and heat is what blows out tires.
  11. Dec 29, 2008 at 10:08 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    I just put 30 psi, side of the door says 29, but I add 1 psi for slightly (not even noticeable) fuel mileage.
