dumb question....but necessary.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackass, Nov 23, 2012.
  1. Nov 23, 2012 at 1:20 PM
    Jackass
    Jackass [OP] Well-Known Member
    Jack
    Memphis, TN
    2013 Super White DC 4x4 TRD OR
    This is my first pick up. I've heard it's pretty easy to spin out. Does the VSC prevent that?
    What are the do's and don't's for safe driving in Rain and Ice?
  2. Nov 23, 2012 at 1:22 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im not sure jackass (sorry I had to) :p
  3. Nov 23, 2012 at 1:24 PM
    acdronin
    acdronin Well-Known Member
    Light touch on the loud pedal, most of the weight of the truck is in the front. Always drive slower/safer than a car. Good tires is a huge help.
  4. Nov 23, 2012 at 1:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As long as you don't drive like a "Jackass"!
    I had to do it also! I've driven trucks most of my life and I've never spun out... Just drive like you have some brains and you will be fine.
  5. Nov 23, 2012 at 1:29 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Much easier to spin out on the painted asphalt of crosswalks etc... in inclement weather.
  6. Nov 23, 2012 at 1:31 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I used to slide a lot on a certain turn on the way home every day. The first time it happened it scared me pretty good. I drove slower around that corner and it still happened. After a while I figured it wasn't because of my driving. I would never have a problem in any of my other cars. I found that the stock tires were not gripping good enough. That went away when I got different tires.
  7. Nov 23, 2012 at 1:33 PM
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Jackass... Hahahaha
  8. Nov 23, 2012 at 1:36 PM
    acdronin
    Do this, next time it rains, take the truck out to some big parking lot or some big paved area where you won't run into anything and find out for yourself. Romp on it from a dead stop, crank the wheel and romp on it, roll the rear wheels over a crosswalk and hit the gas, get it up to like 25mph and slam on the brakes. This will tell you what some of the limitations of the truck are. It's light in the rear, in bad weather the rear can break loose. It's not a car, don't try to drive it like one, it can break loose easier and won't handle like a car and takes longer to stop than a car.
  9. Nov 23, 2012 at 1:55 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Ice doesn't care if your 4wd on not, jackass. :D
  10. Nov 23, 2012 at 2:18 PM
    longernamer
    longernamer Active Member
    This is the best advice you'll get.
    When I was 16 I had a '79 Corolla. That winter a couple friends and I spent far too much time in a huge (several city block) parking lot just being stupid. Every time it snowed or got icy we would head there. It was large enough that you could get up to highway speeds before pulling the handbrake, turning too tightly, etc. I learned more in 5 minutes in an empty icy lot than a year of driver's education could have provided.
    /rl
  11. Nov 23, 2012 at 2:29 PM
    Jackass
    Jack
    Memphis, TN
    Thanks for the replies. Note to self:
    1. do not speed like a jackass while raining.
    2. do not think for a second I will be all right on ice with 4x4
    3. may need more room when breaking hard. avoid school zones
    4. I guess VSC won't save me.
  12. Nov 23, 2012 at 2:58 PM
    KiltedRonin
    KiltedRonin Poor Impulse Control
    Ronin
    Silver Spring, MD.
    2011 access cab, MGM, leer 180.
    OK, I gotta get in on this...
    Don't be a jackass :)
