Dumb Tonneau Cover question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 07toyota1991, Apr 12, 2018.
  1. Apr 12, 2018 at 7:42 AM
    07toyota1991
    07toyota1991 [OP] Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    I found a local guy with some 4runner trail wheels and tires for sale. I am hoping I can fit them in my double cab short bed with leaving the factory tonneau cover on. Does anyone have insight to this dumb question lol
    Thanks!
  2. Apr 12, 2018 at 7:50 AM
    4RUNNER WITH A V8
    4RUNNER WITH A V8 Well-Known Member
    chicago
    4runner with a V8
    Doubt it. Can you throw one in the cab. Maybe 3 will fit in bed covered
  3. Apr 12, 2018 at 7:51 AM
    TonyWhats
    TonyWhats Well-Known Member
    Anthony
    NYC
    2021 Powerwagon 75A
    If you mean put them in your bed and close the cover, yes I don't see why they wouldn't fit.
  4. Apr 12, 2018 at 7:58 AM
    07toyota1991
    The tonneau will fold up on two sections but the section closest to the back glass does not fold up towards the cab. The tonneau doesn't need to be covered, but didn't want to have to remove it.
  5. Apr 12, 2018 at 8:01 AM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    They’ll fit with the back two sections folded up
    Edit: are the tires mounted or are they separate?? I did the same thing with wheels and tires but they were mounted and I didn’t have any issues
  6. Apr 12, 2018 at 8:04 AM
    07toyota1991
    They are mounted. They are 17" with 265/70/17 tires. I don't see why they won't fit but traveling an hour and a half, I would hate to get there and they not you know.
  7. Apr 12, 2018 at 8:21 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You’ll be able to angle them up a little giving you more room. If not bring a ratchet strap and leave the cover folder towards the truck and strap the 4th behind the cover on top of the 2 towards the rear. Shouldn’t be any problem to worry about. Or you could leave them standing up side by side. With the tonneau open it should fit between there and the tailgate and you can run a strap overtop or through the spokes to hold them in
  8. Apr 12, 2018 at 8:26 AM
    Ram.95
    Ram.95 Well-Known Member
    2017 Black Tacoma TRD OR 4x4 Dallas Tx
    TRD PRO Bilstein Suspension HS Progressive AAL
    I do not have the factory Tonneau but I have a tri fold one and had all 3 folded up to fit my 4 stock wheels and the spare in the bed. I would suggest that you bring something to tie down the wheels with. In my 5 mile drive home from Discount, there was a lot of shifting going on in my bed.
    Good choice on the wheels!
    phsycle and 07toyota1991[OP] like this.
  9. Apr 12, 2018 at 8:34 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I have LB but had a bunch of extra room when throwing wheels and tires in back. You should be fine but as mentioned before, pack a ratcheting strap just in case.
  10. Apr 12, 2018 at 9:05 AM
    07toyota1991
    @Ram.95 I happen to have a black truck as well. I love the look of yours! I am getting the wheels with the black accents.
    Ram.95 likes this.
  11. Apr 12, 2018 at 10:02 AM
    t6p
    t6p Active Member
    New York
    You can probably fit them all in the bed. I needed to secure mine over night when I did something similar. I was able to put two in the bed (cover closed) and two in the cab.
  12. Apr 16, 2018 at 11:03 AM
    07toyota1991
    @Ram.95 Did you use the 4runner tpms sensors when changing?
  13. Apr 16, 2018 at 12:08 PM
    Ram.95
    No, they used my stock ones. My wheels did not come with TPMS.
  14. Apr 16, 2018 at 3:06 PM
    phsycle
    phsycle Well-Known Member
    CA
    @Ram.95 Can you post a head-on shot? I believe 4Runner rims are slightly wider and slightly less offset (less backspacing).
  15. Apr 16, 2018 at 3:29 PM
    Ram.95
    Ill try to get one for you tonight.
    phsycle[QUOTED] likes this.
  16. Apr 16, 2018 at 5:55 PM
    Ram.95
    Not the best shot due so the sun.
    Should be able to do better in the morning. I’m running 255’s so factor that in to the look of the width
