Dumbest dashboard light ever
Discussion in 'Off-Topic Discussion' started by righty, Aug 21, 2018.
  1. Aug 21, 2018 at 2:31 PM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    We've had many an ignition switch and/ or cylinder fail, but mostly on the older Accords Pilots and Odysseys. Not chronic, but not uncommon.
  2. Aug 21, 2018 at 2:38 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I don't like key fobs to begin with. Push to start needs a functioning fob to work. Some vehicles might start with a standard key. MB can be start with their turn key fob if you remove the start button. IDK if any other manufacturers have a removable start button. Removable start button, with a standard turn key would be a good idea.
    Masshole_And_His_Taco likes this.
  3. Aug 21, 2018 at 2:40 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I would make it use its last juice to zapp the owner real good
    stomachbuzz[QUOTED] likes this.
  4. Aug 21, 2018 at 2:41 PM
    batacoma
    batacoma Truck Wars
    I'm sure they do fail, I've never experienced it myself, and it probably isn't an expensive fix.
    What cost more a replacement fob, or switch and cylinder?
  5. Aug 21, 2018 at 2:45 PM
    batacoma
    batacoma Truck Wars
    Isn't it like a AA battery icon?
  6. Aug 21, 2018 at 2:46 PM
    Switch and cylinder by a long shot.
  7. Aug 21, 2018 at 2:49 PM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    100% without question.
  8. Aug 21, 2018 at 2:51 PM
    batacoma
    batacoma Truck Wars
    I rather take my chances with a standard ignition.
  9. Aug 21, 2018 at 2:54 PM
    That's my disposition as well. I'm not a fan of a lot of the new technology they're cramming into new cars, but being a parts guy at a dealership I see more of the cons than the pro's.
    batacoma[QUOTED] likes this.
  10. Aug 21, 2018 at 2:55 PM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    That's fine. But you're opinion of "push button start and key fobs are junk" has 0 support or factual evidence. It's just you resisting innovation and change.
    A push button start is the natural progression. Once you think about it, inserting a key and twisting is an archaic idea.
    I see absolutely zero downsides to having push button start, and no reason why a manufacturer would cling to antiquated key and ignition switches.
  11. Aug 21, 2018 at 2:56 PM
    Also a very valid point.
  12. Aug 21, 2018 at 3:00 PM
    batacoma
    batacoma Truck Wars
    Key fobs junk up my key ring, I don't like all that stuff hanging of my belt loop. I'm not going to start carrying a murse just to put my keys in.
  13. Aug 21, 2018 at 3:01 PM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    I don't see many advantages to them either. But, as a car manufacturer who is pressured to come out with new features, I think it's just the natural process.
    TBH, ignition switches have been a big issue sometimes. Anyone remember Chevy's huge recall with failing ignition switches? On the Cobalts and some other models I believe.
    That wasn't that long ago, like 7-10 years.
    In that situation, the ignition switch was actually turning all the way off, and locking the steering wheel. Once you think about it "Hmm...this is 2009...why do we still use this stupid system of a physical key and twisting motion...?" especially combined with other issues such as this ignition switch failure, fumbling with the key in the dark, ignition switches fatiguing if people have a heavy keychain, accidentally draining the battery by leaving the key on "on" or accessory.
    It's just not a concept that anyone would newly invent in this day and age. It doesn't make sense.
  14. Aug 21, 2018 at 3:03 PM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    lol. I guess you don't use fobs at all then. I bet you walk right up to your door, and un/lock with the key - every single time. On your shiny 2012 Tacoma? I bet you even miss the keyhole a couple times a week, and your door has small scratches every where.
    And then I bet, after every single time you use the key to physically unlock the door, you slowly reach down and put the key back in your pocket, so you don't grab the door handle, key in hand, and do this?
  15. Aug 21, 2018 at 3:08 PM
    #35
    batacoma
    batacoma Truck Wars
    Yes I know how to use a key.
  16. Aug 21, 2018 at 3:10 PM
    #36
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you can't open a door with a key and not scratch your door then you are an idiot/lazy or careless. Either way it's behind the actual handle so unless it's a show car who gives a toss if it's scratched there.
  17. Aug 21, 2018 at 3:12 PM
    #37
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    Let's see pictures of your little cubby hole then
  18. Aug 21, 2018 at 3:14 PM
    #38
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    What cubby hole do speak of?
  19. Aug 21, 2018 at 3:15 PM
    #39
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
  20. Aug 21, 2018 at 3:18 PM
    #40
    batacoma
    batacoma Truck Wars
    You should keep ignition keys separate from your other keys.
    I do like the AJT fobs, if you have to use a fob for your Tacoma.
    Hmmm it's 2018, why use a stupid old fob. Get a RFID chip implanted in your index finger use that as your smart key. :rofl:
