Dummie Lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PHaslam, Feb 5, 2011.
  1. Feb 5, 2011 at 4:23 PM
    PHaslam
    PHaslam [OP] Member
    1998 Tacoma TRD 4X4
    3 inch lift
    My ABS,4WD and Cruise Dash lights won't light up. 4wd does work but the cruise and abs don't. Also diff lock just blinks and doesn't seem to engage. If the bulbs in the dash cluster are burnt out would that prevent those systems from working?
  2. Feb 5, 2011 at 4:24 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    fuses??
  3. Feb 5, 2011 at 4:26 PM
    PHaslam
    PHaslam [OP] Member
    1998 Tacoma TRD 4X4
    3 inch lift
    checked all fuses with multimeter and test light? puzzled!:(
  4. Feb 5, 2011 at 4:29 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    wow, got me. maybe a trip to the dealer is in order. free bump for an answer
  5. Feb 5, 2011 at 4:34 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    your diff wont work unless you do the gray wire mod
    Now is the dimmer switch turned down? does the dash light up when your head lights are on?
  6. Feb 5, 2011 at 4:35 PM
    PHaslam
    PHaslam [OP] Member
    1998 Tacoma TRD 4X4
    3 inch lift
    Yeah, closest dealer is a two hour drive. Booourns!
  7. Feb 5, 2011 at 4:37 PM
    PHaslam
    PHaslam [OP] Member
    1998 Tacoma TRD 4X4
    3 inch lift
    Dash lights are turned up. Don't know why I would have to do a mod to make the factory diff lock switch work? Am I missing something?
  8. Feb 5, 2011 at 4:40 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    the diff will only lock when it is in 4low.. doing the mod will make it so it will lost anytime.
    your ABS light will only light up when your ABS is turned off..
  9. Feb 5, 2011 at 4:50 PM
    PHaslam
    PHaslam [OP] Member
    1998 Tacoma TRD 4X4
    3 inch lift
    Yeah tried to lock it in in 4 low still no dice! Waited for about a min with the light blinking. ABS light won't even light up for a couple secs during start up during the bulb check. Just wondering if your your dummie light bulbs are out if they will stop the power from getting to the system? ie: cruise control. Have a very ice covered parking lock and i slammed on my brakes to test the ABS and it didn't pulse on/off like on our newer car?:confused:
  10. Feb 5, 2011 at 4:56 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    did you roll forward a few feet after you turned it on?
  11. Feb 5, 2011 at 5:29 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    I know mine came with ABS but I have the limited..
  12. Feb 5, 2011 at 5:37 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    I dont have power seats but i dont think they had that yet.. But yes I have power everything..
  13. Feb 5, 2011 at 7:19 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    No such thing as powered seats in a tacoma :D
