dump the exhaust?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98fourbangertaco, Aug 24, 2010.
  1. Aug 24, 2010 at 7:15 AM
    98fourbangertaco
    98fourbangertaco [OP] Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I have been debating just cutting my exhaust right after the factory muffler and wielding a turn down on to get rid of that nasty looking pipe that comes out behind the passenger tire mainly but my pipe also hits my leafs at full flex and I think it would just give the truck a cleaner look, has anyone else done this to varify if it changes sound or anything, thanks
  2. Aug 24, 2010 at 8:26 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I have had dumps on my Mustang for years... I will never go back to tail pipes on it. I would not hesitate doing a dump on your Tacoma either. When I get far enough along with mine to put a muffler on it... Thats where it will be ending as well.
  3. Aug 24, 2010 at 9:54 AM
    zxbryantx
    zxbryantx Active Member
    Josh
    Northwest Arkansas
    99 Tacoma 4x4
    Home built front bumper, sliders, and rear bumper, 3in Lift, Deck Plate Mod, Blinker Mod, Gas Can windshield washer container mod :))
    I haven't noticed anything different about mine.. it dumps off right after the muffler.
  4. Aug 24, 2010 at 10:08 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I don't think you would notice any power or fuel milage differences, but it looks cleaner and give a little more tone.
    I love the rumble my mustang has with the dumps, but 510whp will no doubt give it more rumble.
  5. Aug 24, 2010 at 10:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I cut my tailpipe when I put on the new spring packs. Had to, it wasn't going to clear. I cut it after it goes over the axle. Dumps between the spare tire and the leaf spring. Definitely changed the sound of the magnaflow. It sounds OK but I'm not sure if I like it better or not.
