dumping jardine exhaust
Discussion in '4 Cylinder' started by beastlytaco, Sep 18, 2009.
  1. Sep 19, 2009 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  2. Sep 19, 2009 at 8:41 AM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    well, sreally i would like to have higher end power, but i dont want it to rob me of low end torque.
  3. Sep 19, 2009 at 10:35 AM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    I was getting at changing one component will affect the others. The backpressure will be reduced(great that's what we're after), and a restriction removed but the velocity of the exhaust will go down. You stated that higher exhaust velocity is better. Most cat backs I've installed increase the pipe diameter, not alot but it's another change.
    Everything in the link I posted supports your arguement.
    Some folks could've interpreted your statement the wrong way is all.
    I guess my question is, how do you remove a restriction in an exhaust, decrease the backpressure and at the same time maintain or increase the exhaust velocity?
  4. Sep 19, 2009 at 12:40 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    most factory mufflers are restrictive by design and serve only one purpose - to keep the exhaust gas quiet as it exits. removing that one component and replacing it with straight piping of the same size would actually increase velocity. by how much is another thing. just remember that ANY restriction will slow down velocity and hurt the entire power band.
    what we as enthusiasts do for the street is a compromise... we want the best flowing system possible BUT without excessive noise. why do you think race cars are so loud?..... unrestricted exhaust.
    that said, our trucks have one of the best exhaust systems I've seen on a non-sports car application. The muffler may be restrictive, I really don't know, but the rest of the mandrel piping and cat look about as good as it gets. plus the size of the piping is very generous, obviously supporting the large 2.7L motor we have. the only area that looks a bit small, imo, is the primary tubes on the header - but thats a whole other topic ;)
  5. Sep 22, 2009 at 8:32 AM
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    http://www.youtube.com/watch?v=ridQXO0TTTg heres a video of mine. I have a thrush welded muffler and i originaly just had the muffler under the cab and nothing else...that sucked loud and abnoxious! but i did the turndown before the axle and its a nice sound on accleration and at idle almost stock love it. i can have conversations with the quietest person but also get a good rumble.
