Dumping landscaping stones in bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Feb 25, 2011.
  1. Feb 25, 2011 at 10:32 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Same with my truck way back in the day. Took it like a champ.
    The composite bed is remarkably strong.
  2. Feb 25, 2011 at 10:38 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    why not rent a truck or borrow a friends full size truck?
  3. Feb 25, 2011 at 10:40 AM
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    If you are at a rock yard they will put your truck on a scale. I have a dc sb and loaded about 1500lbs of rock without any problems. I was only driving avout 3 miles from my house though. You might be surprised by how little rock you actually get to reach that 1500 lbs. 6 loads later and I was done. If you need a lot just pay the $30 for delivery. One trip from a dump truck and if they can dump it in the right place, you can be done working in an hour instead of spending all day shoveling rock.
  4. Feb 25, 2011 at 10:41 AM
    mjp2
    NJ
    Probably because he already has a pickup capable of handling the job. ;)
  5. Feb 25, 2011 at 10:45 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    just sayin, since he seem's a little worried about damaging his truck. I always borrow my friends full size Chevy for loads im not comfortable hauling with my truck.
  6. Oct 26, 2012 at 4:12 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The composite bed is pretty tough. Still, depending on how big and how far/carefully the bobcat operator dumps them it will probably scratch or gouge it pretty good if not protected at all. But then, it's a truck and you're using it as intended :). AT LEAST it won't rust on you... double plus for the composite bed!
    I have a stall mat I use, a lot tougher than most commercial bed mats, that would protect against large stones but if one should roll into the wall while being dumped it could scratch/gouge anyway.
  7. Oct 26, 2012 at 5:16 AM
    ManMan
    ManMan Well-Known Member
    Didn't hurt mine! Didn't even complain with the trailer full of rock behind it either
  8. Oct 26, 2012 at 7:47 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I really doubt it will hurt it, these beds are tough. Just make sure he doesn't drop the load from high up, that or just shovel it in.
