Durability of performance mods with LT
Discussion in 'Long Travel Suspension' started by ocherp, Jan 14, 2012.
  1. Jan 14, 2012 at 9:24 AM
    ocherp
    ocherp [OP] Well-Known Member
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    Just wondering what you guys have done, engine wise and if you've had any issues. I'm currently running the URD S/C kit and JBA headers with no issues, looking at getting the IPT Valve Body Upgrade very soon and considering some other performance mods but wanted to make sure it's durable enough.
  2. Jan 14, 2012 at 10:09 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    a large trans cooler has helped greatly with the longevity of my transmission. never went with the ipt valve body upgrade because i never really saw a need.
    i am a firm beliver with keeping things stock engine wise unless a good deal of money can be thrown at it to do it right. need more acceleration, gear it.
    ive found the 4.0 could use some better headgaskets since i took one out with a stock engine at around 70k. beside superchargers theres not a whole lot performance wise that can be done without opening up the motor.
    the big question is , durable enough for what?
    id start with durability upgrades like trans cooler, ps cooler, stronger rear axle, spares, quality intake system , wideband o2 and maybe a fuel system with a replaceable filter. better brakes also comes to mind , i know my caged truck needs it.
  3. Jan 14, 2012 at 2:26 PM
    ocherp
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    Currently have the 85mm pulley, looking at the 70mm and VB upgrade and tuning it with Split Second program.
    Durability wise, just talking in terms of all the added stress and what not, with the bigger tires, cage, etc. I know the stock Toyota engines will definitely last, just seeing what has been done out there for increased HP and torque.
  4. Jan 16, 2012 at 6:29 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    I run the 2RZ (2.4L) and my suspension cant keep up with my motor. After you start adding weight to the truck and or bigger tires in most cases you end up running lower gears like myself with 4.88's with 33x10.5 tires.
  5. Jan 17, 2012 at 6:56 AM
    ocherp
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    Just looking to increase my hp and torque, with my cage, Walker Evans and 35" BFGs I still have more power than a stock Tacoma but just want more now :D
  6. Jan 17, 2012 at 7:00 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  7. Jan 17, 2012 at 6:34 PM
    ocherp
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    That would put me a tad over budget :D
  8. Jan 17, 2012 at 7:46 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    Why add the valve set up if u don't even wheel Ur truck to its potential?....
