Duralast Brake Pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by green2002taco, Feb 2, 2016.
  1. Feb 2, 2016 at 7:18 PM
    green2002taco
    green2002taco [OP] New Member
    4x4, regular cab, 2.7 L, manual transmission, 200K miles
    Guys:
    I have a 4x4 with the 2.7L, regular cab.
    I need to replace my front brakes and I bought some Duralast Part Number: MKD799. After getting them home I noticed the one with the wear sensor is around 1-2 mm thinner than the other one. Does this seem OK? Does the wear sensor pad ( thinner ) go on the inside or outside of the rotor?
    Thanks in advance.
    Toyota4x46921 likes this.
  2. Feb 3, 2016 at 12:33 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Try bending the thinner one to match the thicker one. It was prolly bumped during packaging. They go on the inside.
