Duratrac actual sizes?
Discussion in 'Wheels & Tires' started by motoxmann, Apr 9, 2012.
  1. Apr 9, 2012 at 6:54 PM
    motoxmann
    motoxmann [OP] Well-Known Member
    Bay Area
    2009 TRD Sport
    Fox 2.5 RR coilovers, Fox 2.0 piggyback rear, toytec aal, TC UCA's, weathertec liners, Wet Okoles, grillcraft in the mail
    Im looking to pick up a set of Duratracs and am having a hard time deciding on size. I've got Fox shocks up front giving about 2.5-2.75 of lift, and I'm deciding between 265 or 285. The 265's are listed as 31.7 and the 285's 32.8. I've been reading different stuff about the actual sizes being a little smaller than whats listed and was hoping that anyone that had a set could chime in. The 265's are obviously cheaper but theyre also lighter which would save on the mpg a bit. I'm just afraid of them looking too small. Any thoughts?
  2. Apr 9, 2012 at 6:56 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    I have 3 inches of lift and run 265/70/R17's. Love my duratracs.
  3. Apr 10, 2012 at 7:42 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    With that amount of lift I think you will be doing a lot of cutting for 285's. I have 265/70-17's sitting in my garage waiting to be installed on my wheels, and I can tell you they look quite large for a 265 tire. I measured them to be 32" tall, and over 11" wide.
  4. Apr 10, 2012 at 7:53 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    A mid travel lift has ABSOLUTELY NOTHING to do with what size tires you can fit on your truck.
    A lifted truck still has it's tires limited by the same exact thing as a stock truck....the bump stops.
    The bigger the tire the more rubbing regardless of what size lift you have.
    I know someone who has a 3" of lift and 1" of body lift that still rubs his 285's.
    I currently rub 265/70/17's on 2" of lift.
    Caster is more important in regards to rubbing then a lift IMO.
  5. Apr 10, 2012 at 8:06 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Where are you rubbing at with 265/70/17s? Front mud flaps aside my 265/75/16 Duratracs didnt rub when i was at stock height.
    As far as your question OP id just go with 265s in a Duratrac thats what i have with my 3" of lift and it looks fine.
  6. Apr 10, 2012 at 8:09 AM
    XXXX
    sKiP
    05 Prius
    Mud flap area....and mine are trimmed so much there is next to nothing left.
    Every truck is different and like I said caster plays a large role in rubbing.
  7. Apr 10, 2012 at 8:12 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    go 285s..they look so much better and you will be so much more happier
  8. Apr 10, 2012 at 8:18 AM
    XXXX
    sKiP
    05 Prius
    Who gives a shit what a truck looks like if he can't pull out of his driveway without rubbing his fenders off?
    Function > Form
    My truck is mainly used in swamp land and driving through sugar sand. Never once have I gotten stuck for lack of floatation that a wider tire would have helped me out of. Never!
    Unless your going to cut the cab mount, trim fenders, remove mud flaps, etc...285's "IMO" are for posers.
  9. Apr 10, 2012 at 1:57 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Quad X, what are you running 265/70r17? This is good to hear, as I'm down here in Florida where there is nothing but deep swamp and sugar sand. The stock Dunlops are...OK at best off road. Thinking on 275/70r17, all stock, hopefully
  10. Apr 10, 2012 at 1:59 PM
    Gearheadesw
    Davenport Fl
    Quad X, what are you running 265/70r17? This is good to hear, as I'm down here in Florida where there is nothing but deep swamp and sugar sand. The stock Dunlops are...OK at best off road. Thinking on 275/70r17,in some other tire, all stock, hopefully
  11. Apr 10, 2012 at 7:48 PM
    motoxmann
    Bay Area
    2009 TRD Sport
    Thanks for the replies guys. Im just gonna go With the 265's. That way I know they'll work with no problems. Now just to find a set. They seem to be out at most places
  12. Apr 10, 2012 at 7:53 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I had the 265 Duratracs and everyone that saw them thought I was running 285's
  13. Apr 11, 2012 at 5:10 AM
    XXXX
    sKiP
    05 Prius
    yep.
    they look and function plenty good to me
  14. Apr 12, 2012 at 10:50 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    They just pulled my truck into the bay now to put on a set of 265/70/17. Will know in about 30 min if it was a wide choice or not
  15. Apr 12, 2012 at 10:50 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    They just pulled my truck into the bay now to put on a set of 265/70/17. Will know in about 30 min if it was a wise choice or not
  16. Apr 12, 2012 at 10:53 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had 275/65/18s and they were 32.1 OD on the GY site and measuring tape said same thing. Good luck...........
  17. May 6, 2012 at 5:38 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    YES they do look much better but it's much heavier and you'll loose a bit of power. too bad you can't get c range on a 285's.
  18. May 6, 2012 at 5:59 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    i have 3 in of lift and 285/75/16 duratracs. easily doable.
  19. May 6, 2012 at 6:04 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    X2
