Duratrac help!!!
Discussion in 'Wheels & Tires' started by ryanb33, Sep 7, 2011.
  1. Sep 7, 2011 at 3:39 PM
    ryanb33
    ryanb33 [OP] New Member
    Milton,Fl
    2010 TRD Off Road
    I just purchased some good year duratracs 265-75-16 load C. I installed 5100's on all 4 corners and set the fronts to 1.75. I had the front end aligned also. I like the ride but running on the interstate starting at 75 mph the truck wanders it feels like there is play in the steering. I had decreased and increased the pressure but nothing helps.
    Anyone have any ideas???
  2. Sep 7, 2011 at 3:48 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    http://i.cdn.tacomaworld.com/host/tacomaworld/forum/images/smilies/extras/worthless.gif
    :worthless:
    Sounds like a poor alignment. Wondering, sounds like the castor. What are the settings and who aligned the truck? Dealerships usually set the truck to factory settings, but with a lift and bigger tires those settings aren't always the best.
  3. Sep 7, 2011 at 3:51 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    sounds like you need an alignment
    if the alignment doesn't straighten you back out, you may need new uca's to compensate for the lift..
    when you get your alignment done, as for your alignment printout before and after...then post your results here
  4. Sep 7, 2011 at 3:52 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    what they said
  5. Sep 7, 2011 at 4:13 PM
    ryanb33
    Milton,Fl
    2010 TRD Off Road
    Thanks for the fast replys. The place I purchased the tires did the alignment and installed the shocks. I'm pretty sure he aligned the truck to factory specs. That might be an issue. I was thinking about taking to the Good Year dealer tomorrow to see if they can help. The tires had alot of good reviews and no one hasn't really had this issue so I don't believe it's the tires.
    Thanks everyone.
  6. Sep 7, 2011 at 6:53 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2008 P71
    Yes
    Part of it could be the tires. It takes a couple hundred miles to "break in" these tires. Mine were a little squirrelly when I first got them, but then they smoothed out.
  7. Sep 7, 2011 at 6:54 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    probably not your UCA's but I could be wrong.. 265's are small tires and 1.75" of lift isn't that much so you should have plenty of room left to align.
    Try this: negative caster 3.2 degrees, -1 degree camber, toe slightly in. Should drive straight. Either that or maybe the wheels aren't balanced.
    Every truck is different so hard to tell.
    Did the shop do a laser alignment?
