Duratrac mpg vs Nitto Terra Grappler MPG
Discussion in 'Wheels & Tires' started by Duartizzle, Mar 28, 2013.
  1. Mar 28, 2013 at 10:12 AM
    Duartizzle
    Duartizzle [OP] Well-Known Member
    Huntington Beach, CA
    Double Cab 4x4 TRD Off-Road
    So I have done a lot of searching about the differences between the two tires. I know the tread on the Duratrac is a crossbreed of A/T and M/T but comes in a c range and is a few pounds lighter than the D range Nitto Terra. I was curious if anyone knew the MPG difference if any between the two tire, I realize that the c range is lighter but due to its extreme tread nature, wondering if it got worse mpg than the d range. I am looking to buy a 265/75/16 tire.
  2. Mar 28, 2013 at 10:25 AM
    BulletToothTony
    BulletToothTony Space for rent
    You can call me Susan if it makes you happy.
    What size are you looking for? 265, 285...
  3. Mar 28, 2013 at 10:36 AM
    Duartizzle
    My apologies, I should have included that. Looking into a 265/75/16
  4. Mar 28, 2013 at 12:05 PM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I had Nitto Terra's first, 265/70/17 and averaged around 15-17 with about 2' of lift.
    Now have Duratracs in 285/70/17 and average about 14-16 with a little over 3' of lift.
  5. May 6, 2013 at 11:24 AM
    bolio
    bolio Well-Known Member
    San Antonio
    08 trd OR 4x4
    I have Duratracs in that size and lost about 1mpg when I wore out my BFG AT's that were 265/70/16 D, even though the Duratracs are lighter by 4lbs on paper, but the tire is taller so that might be a factor also. I would guess there would be very little difference between the 2 with only 3 lbs difference and same size, but the Duratracs being more aggressive. I believe the Terra's come with a 3ply sidewall in that size compared to the 2ply dura's, and there have been reviews stating the dura's do have weaker puncture prone sidewalls. They also get some of the best reviews for snow, so it also depends what type of off roading you do. My next tire will be the Terras in that size.
