Duratrac vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B3nd3r, Aug 19, 2014.
  1. Aug 19, 2014 at 11:33 AM
    B3nd3r
    B3nd3r [OP] Active Member
    2009 tacoma trd
    Anyone else with duratrac tires have vibration. When I get up to 60+ miles per hour I get bad vibration in my steering wheel. Doesn't do it at slow speeds. The tire company I had put them on did balance and align them.
    Just curious
  2. Aug 19, 2014 at 11:40 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hm, I installed them 2 weeks ago and haven't been on the highway yet. I will be taking a little trip Friday evening and can report back with my findings.
  3. Aug 19, 2014 at 11:43 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    no vibes with mine...about 10k miles on them.
  4. Aug 19, 2014 at 12:02 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Right now it sounds like they weren't balanced well.
    Has anything else changed since the time you weren't getting vibes at 60mph?
    A couple causes I've seen over the years:
    • Wheel Bore being larger than the hub bore without self-centering lug nuts.
    • Poorly balanced Tires.
    • Tire Tread uneven due to extended periods of driving a misaligned vehicle.
    • Loose suspension bolts (scary!)
  5. Aug 19, 2014 at 12:06 PM
    TacomaToday
    TacomaToday Well-Known Member
    Keye
    Orange
    BSP 2010 4x4 Double Cab LB
    De-Badged, Satoshi Grill/Grillcraft insert, SnugTop lid, LS460R Retrofit Headlights by AndrewTRS. VLED 5000K LED Foglight bulbs, Blacked Depot Tail lights with VLED bulbs.
    Have 30k on mine. No issues.
  6. Aug 19, 2014 at 12:14 PM
    SlvrV8Rnnr
    SlvrV8Rnnr Member
    I've had mine for almost 2 weeks. Got close to 500 hundred miles on them so far. I have a slight vibe/steering wheeling shake around 55-60 but otherwise there is no shake before then and they ride great up to 75mph. It's just that little window where I feel some vibe. I haven't decided if I'm going to go back for a rebalance or not. Otherwise I love these tires. Great look and ride on street. Have not had them in rain, mud or snow yet.
  7. Aug 19, 2014 at 12:23 PM
    B3nd3r
    2009 tacoma trd
    Mine were installed yesterday. Only have like 10 miles on them. The Goodyear dealership balanced them but said it was because it is an aggressive tire. I'm not really believing it.
  8. Aug 19, 2014 at 12:30 PM
    southbound
    southbound Member
    Mine vibrate pretty bad between 65-70. Had them balanced three times, road force once. Still the same. I do have the 235/85 load range e, a buddy has the 265/75 load c and his are fine.
  9. Aug 19, 2014 at 12:36 PM
    KMitch
    Colorado
    Mine are E's and I have no issues.
  10. Aug 19, 2014 at 3:28 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Probably too much road force or they are out of round.
    Most Goodyear tires seem to suffer from this.
    If road force is above 20lbs then you will definitely feel vibrations.
  11. Aug 19, 2014 at 4:30 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    ^^^ This. One out of the four of mine was slightly egg shaped. Road force balanced the bad one and was all good. I would kept taking it back until they get it right or demand a new set.
  12. Aug 19, 2014 at 4:32 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    No vibrations whatsoever! Make sure they were 'computer-matched / road force balanced'. I costs a little extra but makes a big difference!...
  13. Aug 19, 2014 at 4:37 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Just got done dealing with this myself Op. I just had new BFG AT's installed, had a blowout on freeway with stock, rubber, so said eff-it at the tire store and bought four new BFG AT's. I had a 20 minute highway ride when I left, and it felt like the truck was rattling apart on the way home, because the shakes and vibes were so bad between 60-70 mph.
    Got home, pulled front wheels off, moved them to the rear. Re seated the wheels and semi tightened nuts down with truck in air. Problem solved, smooth as glass. My tires are 265/75/16, no lift, or level. Had to slightly trim flare and mudflaps near rear of wheelhouse opening.
    Love the look and ride, all though the new rolling resistance seems to tax my base OE shocks.
    I also have hub-centric rings in my wheels, because my aftermarket wheels are not Toyota hub-centric.
  14. Aug 19, 2014 at 4:56 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    YES!! I've had these issues for a while now. About 25-30k miles on the tires. I've had the vibes for about the last 7-8k miles. Ive had the tires balanced twice with no complete fix.
    Before the first attempt, my vibes were so bad that it was dangerous to drive on the highway. Got them balanced, but there was still a lot of vibration. Got them balanced a second time at a better tire shop. Vibration was a little better, but it still vibrates. I'm really not happy with these tires.
    Both times they were road force balanced.
  15. Aug 22, 2014 at 12:40 PM
    B3nd3r
    2009 tacoma trd
    Well im at the shop to get them rebalanced. Lets see what happens.
  16. Aug 22, 2014 at 2:26 PM
    degu2000
    degu2000 Well-Known Member
    This is a bullshit copout answer. Whether a tire is aggressive or not DOES make it harder to balance/take more weight, but it absolutely does not mean that they will still shake when balanced.
  17. Aug 22, 2014 at 2:38 PM
    Hbr01
    Hbr01 Well-Known Member
    Brian
    Jax, FL
    12 DBC 4x4
    I have a bad one, or it s a bad aftermarket rim which I am replacing with stock rims. I spent a lot of time at the dealer thinking it was a driveline vibration issue, and the dealer tech said it was a tire, rim or lug nuts. Mine was coming from the rear at 45-50 mph and again at 70+. I just rotated them last week and now I have no drive line vibration but now I have a steering wheel shake. Once I get my new factory rims powder coated I am going to have the shop that sold me the tires check them all to make sure I don't have a bad one.
  18. Aug 22, 2014 at 2:53 PM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I had vibes after tread was around 75%. Re-balancing didn't help. Just had to deal with the steering wheel shaking until I got new tires. My buddy had the same problem. Both were "C" range duratracs.
  19. Aug 22, 2014 at 2:57 PM
    DrTaco
    DrTaco Member
    Brandon
    Colorado
    2014 Blue Ribbon Metallic TRD Offroad DCSB
    Icon stage 6 lift with all pro standard leaf pack aund u-bold flip kit, allpro apex sliders, Al apex front bumper and IFS skid, exhaust re-route and magna flow catback, VR8000 warn winch, softopper, 15% tint, clear bra, 265/75-16 duratracs, tree pinstripes
    My C rated 265/75-16 Duratracs do the same thing at 60mph, but it stops at 65mph
  20. Aug 22, 2014 at 3:04 PM
    B3nd3r
    2009 tacoma trd
    Yeah its a little bit better but I still have vibration in the steering wheel at 65mph
