Duratrac vs KO2
Discussion in 'Wheels & Tires' started by PLtacoma725, Aug 13, 2015.
  1. Aug 10, 2018 at 8:39 AM
    #181
    ChronicTaco
    ChronicTaco Well-Known Member
    British Columbia
    Canadian Special
    I have had both. Ko2s for the sidewall strength. Have seen a lot of Goodyear tires with sidewall failures on trails, Duratracs and MT/Rs.
    DavesTaco68 likes this.
  2. Aug 10, 2018 at 8:45 AM
    #182
    GoodOlBoy
    GoodOlBoy Well-Known Member
    Brennan
    2016 MGM TRDOR
    If you’re going to be in a lot of mud or snow, the duratracs will get more traction in those situations everytime. They are a little louder than the ko2s on pavement through. That’s the drawback. Ko2s are good all around tires but the duratracs aggressive tread pattern reallllly bites into mud and snow incredibly well. Other than that and the noise I’d consider them comparable it all other factors.
  3. Aug 10, 2018 at 10:17 AM
    #183
    viking15
    viking15 Well-Known Member
    Joe
    Wish I had know that before I purchased mine last week . I replaced my NITTOS which were pretty good but the KO's look better on the truck
  4. Aug 10, 2018 at 10:25 AM
    #184
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Ford F350, Lexus RX450h, FZJ80, Jeep YJ
    Apple and Oranges really
    KO2s are a true AT and are very good daily driver tire. Duratracs are considered an aggressive AT, hybrid between an AT and MT, will work for a daily but perform better offroad.
  5. Aug 10, 2018 at 10:36 AM
    #185
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    No one has tried that Bridgestone Revo-3?
  6. Aug 10, 2018 at 11:08 AM
    #186
    tacomatime
    tacomatime Well-Known Member
    Florida
    2018 TRD Sport DCLB 4x4
    3" leveling front, and 2" rear Rough Country. BF Goodrich 305/65/17 KO2
    I can't comment on the duratracs as I never had them. But I have the KO2. They weigh around 60lbs each if I am not mistaken. It takes more power to get them moving off the start line. And It takes a lot for them to bog down and start spinning if you're on mud, or sand. I was offroading last weekend, and they barely spun. (Aired down) They have a hell of a grip to the ground. At the end, it all depends on you and where you offroad and so forth. Yes, they have a thick wall that prevents minor debris from causing a puncture, or you get the duratracs with a thinner wall, where chances of flats are higher. Your decision. Good luck. 20180723_183844.jpg 20180809_174112.jpg 20180725_222355.jpg
    CavalryTRD and SilverII like this.
  7. Aug 10, 2018 at 11:10 AM
    #187
    Flash1034
    N/W Montana
    What size are those?
  8. Aug 10, 2018 at 11:12 AM
    #188
    tacomatime
    Florida
    305/65/17. Compare at tiresize.com.
  9. Aug 10, 2018 at 11:25 AM
    #189
    JoeCOVA
    Joe
    Colorado Springs
    I'm not following, they both can come in Load E with the same ply ratings.
    psmura likes this.
  10. Aug 10, 2018 at 2:00 PM
    #190
    ChronicTaco
    British Columbia
    Canadian Special
    It's the side wall. Most tires are 1 or 2 ply where an offroad tire should be 3 ply
  11. Aug 10, 2018 at 2:03 PM
    #191
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Most SL are 2 ply sidewall
  12. Aug 10, 2018 at 2:32 PM
    #192
    JoeCOVA
    Joe
    Colorado Springs
    I’ve seen Duratrac with sidewalls from 2-4 and depends on the tire size.
  13. Aug 10, 2018 at 2:45 PM
    #193
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    This subject(tires) is like an oil thread.....
    I've never torn/blown a sidewalk on a Duratrac. Several sets on a Quigley work can, that saw more abuse than most of the trucks on here.....
    1 set on my Cummins.
    And 1 set on my frontier.
    The only sidewall I've torn recently, was on my KO2s.... but, the rock would've shredded damn near anything anyway.
    While I'd say it's almost a toss up in snow, the KO2s actually seem a little better honestly, they pack up real nice.
    The mud... lol, they both suck. They aren't mud tires.
    That said, get a tire for what you're going to use it for....
    The only reason not going KO2 again, is the load range.
    Otherwise, I'd already have a set on the truck.
    Chase
  14. Aug 11, 2018 at 1:02 PM
    #194
    FrenchiesTaco
    FrenchiesTaco Well-Known Member
    Kevin
    NJ
    2018 Inferno Sport
    20171223_134018.jpg I have Duratrac's on my Cherokee, quite on the highway, great in the snow. I'm going to call my tire guy Monday for pricing.
  15. Aug 11, 2018 at 2:20 PM
    #195
    Harambe4President
    Harambe4President Well-Known Member
    Matthew
    Albuquerque, NM
    2017 Tacoma TRD Pro Cement, 2022 Toyota 4runner TRD Pro
    I had duratracs for 3 weeks. Went wheeling one time in rocks and 2 sliced sidewalls had me changing them out quickly. I considered the KO2 again, but went with the falcon wildpeak mt and they are extremely good tires. There was at no time where I was sliding off of rocks, they just have a reputation for weak sidewalls. I hoped it was only a rumor. But from my experience it was not a rumor. I have had no issue from the wildpeak mts. They are heavier and louder. But they are good. The new bfg km3 have great reviews too. Nitto ridge grapplers are also great. Have had them all but the new km3s.
  16. Aug 11, 2018 at 4:07 PM
    #196
    Arianna
    Arianna Well-Known Member
    Arianna
    Oregon, Washington
    2017 Magnetic Grey Tacoma SR5 Crew Cab
    I have KO2s and do a lot of offroading. I have yet to get stuck bad enough to where I needed assistance. *Knock on wood*
  17. Aug 11, 2018 at 5:36 PM
    #197
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    How do you like the ko2's for water on the roads ?
  18. Aug 11, 2018 at 6:38 PM
    #198
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I have K02s. Really great for everything but snow/ice. Whatever body allows BF Goodrich to apply the “severe snow rating” to the K02s must have been paid off. They are great tires otherwise, but do not deserve their peak/snowflake rating. The stock Goodyears are much better in snow than the K02.
    15+1 likes this.
  19. Aug 11, 2018 at 9:29 PM
    #199
    Flash1034
    N/W Montana
    I wish I could find out if the 265/75/16 and 265/70/16 Duratracs have the 3ply sidewall? Anybody know?
  20. Aug 12, 2018 at 6:05 AM
    #200
    veedo
    veedo Well-Known Member
    Agree. Had the original ko's on two trucks, unsiped they were downright dangerous in snow. Can't imagine the ko2 would be much different. Run duratracs on my work truck, been great with no flats. Run siped duratracs on the fj, very very good, but do get loud when worn down.
    Stocklocker[QUOTED] likes this.
