Duratrac's in stock 245, any comment?
Discussion in 'Wheels & Tires' started by TFLT, Oct 26, 2010.
  1. Oct 26, 2010 at 7:17 AM
    TFLT
    TFLT [OP] Active Member
    Central New York
    10 tacoma Reg cab 4x4
    Yellow Wire, Hella DE Fogs, Firestone airbags
    I am thinking about a set of duratracs to replace the sad stock rubber on my 10' reg cab. I was concidering sticking with the stock size, and I see they are available. I have not seen anyone comment on duratrac's in 245. My truck see's fairly regular off road use, but I have really never needed more lift. The only area I would like to see an improvement in is traction. Any thoughts about the real world advantage or disadvantages of keeping it stock?
  2. Oct 26, 2010 at 7:22 AM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    If you have a prerunner or 4x4 go up to the 265s with out a lift. They will fit. The 245 just look a bit goofy because the proportions are off.
  3. Oct 26, 2010 at 7:30 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    265/75/16 nuff said.
    I have that size duratracs and I plan on going with 285/75/16 when I lift mine.
  4. Oct 26, 2010 at 7:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're not having issues with the 245's why change? I don't think the fatter tire will be much fun in the winter with a 2wd truck.
  5. Oct 26, 2010 at 7:40 AM
    scubascapie
    scubascapie Member
    MA
    2007 4x4
    abs mod, CB, Scanner. firestone riderite kit.265 75 16 goodyear Wrangler DuraTrac., 5100 at .85
    I just got some a couple weeks ago and so far so good like them a lot. Got the 265-75-16
  6. Oct 26, 2010 at 7:54 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    245's are too small, get the 265's.
  7. Oct 26, 2010 at 9:09 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Assuming you're 4x4 or pre runner,
    There's a minority opinion out there that says that a narrower tire is better for offroading.
    There's a slightly larger and more credible minority opinion out there that says that a narrower tire is better for driving on snowy/icy roads.
    You can google up the finer points of this argument if you want. It has to do with coefficients of friction and contact patch loading in lbs/psi.
    But most folks believe that more rubber on the ground leads to better traction. If you're ponying up the pesos for expensive rubber, might as well go with the largest stock size that fits.
    And you *know* that toyota put the 245s on the stock 4x4 for only two reasons:
    1. It's cheaper
    2. To make the difference between "stock" and "TRD" more noticable.
  8. Oct 26, 2010 at 9:45 AM
    Pugga
    Massachusetts
    The tire pressure in PSI is roughly the pressure you're applying to the road surface. A narrow tire will sink down through anything soft which is why they are better in the snow. They sink down to the hard surface below where you can get traction. Wider tires in the snow try to ride on the snow but aren't wide enough in most cases so the partially sink and you end up just spinning in place. But, narrow tires suck in something like sand because there is nothing hard below the soft sand so you get stuck, enter wide tires. Wider tires are NOT always better, it comes down to getting the tire that fits your needs or making sacrifices for looks.
  9. Oct 26, 2010 at 12:40 PM
    TFLT
    Central New York
    Thanks for the thoughts, I should have mentioned it's a 4x4. I dont care what it looks like, I'm strictly going for function, not form. are there any noticable negatives in moving to the 265's re: wheel alignment, or gearing?
  10. Oct 26, 2010 at 12:59 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Is there a cost difference?
    I do not have duratracs, but I kept the stock size of 245/75/16 for both my summer ATs & dedicated winter tires. They were less expensive.
    The tire dealer told me they were just as tall as the 265/70/16s just not as wide. He said if I went with the 265/75s it increases both but the 265s were more expensive.
    That was my experience. I like saving money when I can & both sets of 245 tires have done everything I have needed to do.
  11. Oct 26, 2010 at 1:37 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Go with 265/75/16. Even at $165ish each they're still a great deal compaired to other tires out there. I run 265/75/16 duratracs and they have been awesome. I'm goin to buy duratracs again, when I stuff 305's under my truck.
