Duratracs rub cab mount like a mofo......
Discussion in 'Wheels & Tires' started by ETaco23, Jul 10, 2011.
  1. Jul 10, 2011 at 6:48 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I just got my tires on, and I have my Icons set to about 3" lift, it might be alittle higher.
    They're 285's and I rub my cab mounts pretty bad at full turn.
    I was wondering if my Caster is too low? Its 2.5 and 2.7
    Would a little more caster help much?
    Or should I just leave it were it is and chop the cab mounts?
    Thanks!
  2. Jul 10, 2011 at 6:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What's the backspacing of your wheels, and do you have aftermarket ucas?
  3. Jul 10, 2011 at 6:54 PM
    bobby15
    bobby15 Well-Known Member
    Bobby
    Chino Hills, Ca
    09 DC LB 4x4 magnetic grey tacoma
    tint, Fox 2.5 coilovers, Total Chaos UCAs, bump stops, fox 2.0 piggybacks, All-Pro leaf pack, Nitto Trail Grapplers, Robby Gordon signature series rims, Magnaflow exhaust, Gen 1 TRD cai, blacked out tails, halo head lights, flood lights behind the grill, Street scene grille,L.E.D. dome, map and license plate lights, HID's in the headlights and fog lights, Kenwood touchscreen head unit, fog light mod, vinyl rapped valence, plasti dipped badges ..more to come
    I would do cab mount chop regardless ! I did and i'm pretty happy with the outcome.
  4. Jul 10, 2011 at 6:55 PM
    ETaco23
    Evan
    PNW
    I got TC UCA's and 4.5" BS wheels.....
  5. Jul 10, 2011 at 6:56 PM
    KPT
    09 Prerunner
    Excellent. Chop the cab mounts. :thumbsup:
  6. Jul 10, 2011 at 6:58 PM
    ETaco23
    Evan
    PNW
    will do! :)
    Next weekend..
    can I go a little while without plating it? or should I get it done asap?
  7. Jul 10, 2011 at 7:01 PM
    KPT
    09 Prerunner
    If you are going to wait to plate it, because sure to paint the spots you cut so they won't rust.
  8. Jul 10, 2011 at 8:28 PM
    ETaco23
    Evan
    PNW
    k...
    but I want to know how some people are getting away without chopping them, and have the same set-up as me....
  9. Jul 10, 2011 at 8:31 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    I have 4.5 inch lift and 285's on 4.5 backspacing and no chop.
  10. Jul 10, 2011 at 8:41 PM
    ETaco23
    Evan
    PNW
    I know some guys running 3" lift and no chop, with TC UCA's...
    Oh well... I cant wait to chop them and stop the rubbing! :)
  11. Jul 10, 2011 at 8:43 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i have a 3 inch with stock uca's and no chop, ujelly?
  12. Jul 10, 2011 at 8:56 PM
    ETaco23
    Evan
    PNW
    yeah, I know if I had stock UCA's it would be fine. But I got a mid travel set-up and the TC UCA's bring the tire closer to the body mounts...
    It sucks but atleast my allignment is dead on and it rides great. I geuss I just need to chop it.
    But Im wondering if I do get more caster would it bring my tire foward enough to not rub the body mount?
  13. Jul 10, 2011 at 9:06 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I definitely noticed that my tires were moved forward in the wheel well when I upped my caster from 2.4 to 2.9*... but not much.
    I have Camburg UCAs, they moved my wheels back in the well a bit by design. I have no idea how others are getting away without doing the cab mount chop... unless they never go over an uneven surface. but then again, my wheels are 4" BS so they naturally hit the mount harder (no experience with 4.5 BS).
    I have mine currently chopped but not boxed. Like mentioned above, I just chopped mine when I had the time and painted the cuts for now until I have a Saturday to box them back in. After looking the cabmount over, and reading other's posts on TW, I'm not worried about leaving it un-boxed for a while, just wont go mashing on it too hard until I do.
    Edit: Also, a while back, I saw a member on here, Maxamillion (sp?), was experimenting with upping his caster to 3.5* to help fit his 35s, maybe try asking him.
  14. Jul 10, 2011 at 9:15 PM
    ETaco23
    Evan
    PNW
    huh... thanks for the Info!
    Maybe I should try having my Caster set closer to 3*.... But Im still ganna need to do the chop..
  15. Jul 11, 2011 at 2:20 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Were you thinking of adjusting your castor as a temp thing? Because it doesn't make any sense to run aftermarket UCA's if your going to set your castor all out of whack like mine is with the stock UCA's
    By the way I have 305/70/16's 16x8 and 4" BS'ing and with the stock UCA's I have never hit the cab mount. That's one nice thing about the stock UCA's, they were free and no cab mount chop required. At full lock on flat ground, with no flex, I miss the cab mount by about 1". I have a pic of it someplace.
  16. Jul 17, 2011 at 9:10 PM
    ETaco23
    Evan
    PNW
    I did the cab mount chop yesterday and it went smoothly... Now I just need to get me a welder so I can box it back in. :)
    I love not rubbing. But I really dont like the wheel being so far back. It just looks kinda odd not having the wheel/tire center with the wheel well....
  17. Jul 17, 2011 at 9:47 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Maybe you need another alignment?
  18. Jul 17, 2011 at 9:54 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I have 3" OME with LR UCA's and I do not rub the cab mount.
  19. Jul 18, 2011 at 12:29 PM
    ETaco23
    Evan
    PNW
    do you know what your caster is?
    I kinda want to be closer to 2.8* - 3*
  20. Jul 18, 2011 at 12:48 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    yeah that's ideal. If it's too far back, your caster might be in the 5*+ range. When you get your truck aligned, the TC UCAs will make it possible for them to hit the 2.8*-3* range. Just tell them beforehand.
