Duratracs wearing fast
Discussion in 'Suspension' started by CUtigerfan, Jan 4, 2010.
  1. Jan 4, 2010 at 3:10 PM
    CUtigerfan
    CUtigerfan [OP] Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    I don't want to bad mouth these tires because I love the way they handle on and off road just wanted to get some attention and figured this would get you to read the thread.
    Ok I have an 04 5-lug and installed Daystar spacers and 235/75 Duratracs back in September. I noticed recently that the outside edge of the blocks on both front tires is wearing away pretty quick. I needed to have my oil changed anyway so I took it to the shop that installed the tires and spacers and told them while they were servicing it that I wanted them to check the alignment. They showed me a printout and told me the alignment was fine. One of the guys that worked there told me that they're wearing like that because I put aggressive tires on a 2wd truck and the suspension is setup different than a 4wd. He said the only thing I can do is rotate them every 3,000 miles instead of every 6,000. Does this make sense to anyone? I wouldn't have questioned him if he said it was from driving hard into turns and stuff like that but this doesn't make sense to me. I don't really know what camber but have heard that if it's off your tires will wear prematurely. I also noticed that the front tires looked like they were bowed out slightly but this could just be my imagination getting the best of me when I noticed the tires were wearing like they are.
    Can anybody second what the guy at the shop said or offer a different cause and solution to this problem? These tires only have 3,000 miles on them and need to last a while
  2. Jan 4, 2010 at 3:59 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    do you have stock uca's?
    because if you do thats probably what it is causing the problem.
  3. Jan 4, 2010 at 4:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Do you have a copy of the alignment sheet they showed you?? I have a very hard time believing your alignment is right.
    Just a CYA question-Have you checked the inflation?? There should be wear inside and outside if the air si off...but just in case.
  4. Jan 4, 2010 at 4:07 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I've had mine installed since June and probably have around 10k miles on. I haven't noticed any problems as far as wearing yet (knock on wood).
  5. Jan 4, 2010 at 5:06 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ide say your alingment is out of wack.it wont take long to wear out tires if it is.
  6. Jan 4, 2010 at 7:55 PM
    CUtigerfan
    South Carolina
    04 Base
    I honestly don't think it's the tires themselves. When they check alignment do they check camber or whatever it is?
    Yes they are stock UCA's
    And no I don't have the sheet but I might have to go back and get them to look at it again.
    I'll try to take some pics tomorrow so maybe you guys can tell me if I've lost my mind or not about the top being bowed out more than the bottom
    Oh and the wear is just on the outside of the front tires. the inside blocks aren't getting eaten away at all
  7. Jan 4, 2010 at 8:20 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I have about 5,000 miles on mine and they barely show and wear on them. I just finished the first rotation and they still looked new. OP, your alignment may be out of spec???
  8. Jan 4, 2010 at 8:27 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I had my 3" lift on with stock uca's an the front insides were wearing faster. Getthe alignment specs from someone on here. I'm on my phone right now. Then take it to them and have them dial it in to those numbers.
  9. Jan 5, 2010 at 10:10 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    he has stock ucas,not going to get it to correct numbers.
  10. Jan 5, 2010 at 10:16 AM
    1BlkT
    Ty
    90603
    I'm using stock uca's but then again my coilovers aren't giving me more than 2'' of lift either.
  11. Jan 5, 2010 at 10:17 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    derekabraham has the billys set at 2.5" and stock uca's. I believe his are very close. He has normal wear.
  12. Jan 5, 2010 at 11:05 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    an 04 5lugger and an 05+ prerunner/4x4 are 2 completely different beasts
  13. Jan 5, 2010 at 7:34 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    oh yeah. i just assume everyone has 05 and newer lol.didnt see it in his whatever u call that under his name.thanks for pointing that out.
