Duratracs with stock suspension
Discussion in 'Wheels & Tires' started by nh_yota, Dec 15, 2010.
  1. Dec 15, 2010 at 11:19 AM
    nh_yota
    nh_yota [OP] Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    TRD Exhaust, TRD Skid Plate, URD Short Shift, Duratracs
    Getting a flat tire today has accelerated my need for new tires. I've already decided on the Duratracs in 265/75-16. I have two quick questions as I want to order these tires today:
    1. Will the tire work fine with the stock TRD offroad suspension since it's slightly larger than the stock tire? I'm pretty sure but just wanted to check.
    2. Will I need to get a 5th tire as the spare, or can I just keep the existing spare even though it will be slightly smaller than the 4 other tires? I'm used to driving AWD cars where you need to be careful with mixing tire sizes.
    Thanks
  2. Dec 15, 2010 at 11:32 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Tires will be fine as far as suspenion goes. They will probably rub the front mud flaps at times.
    Not sure about the spare, I've wondered the same thing.
  3. Dec 15, 2010 at 11:35 AM
    08chocotaco
    08chocotaco Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    they wont rub on stock suspension. i had A/T same size on stock for a year and never rubbed, but turning radius might be SLIGHTLY, i mean slightly, wider then usual. But that might have been my lift on it that helped
  4. Dec 15, 2010 at 11:45 AM
    jtav2002
    Josh
    Reading, PA
    Yep, the Duratracs rub. I just removed my front mud flaps since I'm not lifting yet.
    Wonder if a spare Duratrac will fit underneath where the stock spare is?
  5. Dec 15, 2010 at 11:54 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have 265/75/16 duratracs and have zero rubbing issues on or off road. I have had it at full lock and stuffed with no rubbing offroad.
  6. Dec 15, 2010 at 12:26 PM
    nh_yota
    Jeff
    Portsmouth, NH
    I would think a smaller spare could work as long as you're not in 4WD the whole time. I just don't want to have to spend money on a 5th tire that would never really get used.
  7. Dec 18, 2010 at 10:57 AM
    08chocotaco
    TAYLOR
    the spare will get you to a tire shop or home if your around town. Do you have the one thats highway friendly?
  8. Dec 18, 2010 at 11:06 AM
    jtav2002
    Josh
    Reading, PA
    Hm, you seem to be in the minority. You're the first person I've heard with no front mudflap rubbing with that size Duratrac.
  9. Dec 18, 2010 at 11:47 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    Chances are you will have to do one of two things, either remove your mud flaps, or trim them down on the tire side (there is a hump there that the tire likes to rub on). I ran that duratracs for roughly 6 months without a lift and never had any real issues. But I did have to trim my mud flaps in order to stop the rubbing. I chose to keep the mud flaps on as the DT have a tendency to pick up and toss stones down the side of your truck. If you're not worried about your paint, then I say just take them off. The DT are a lot more aggressive than most tires of the same size, and those lugs really like to grab onto things in your fender.
    I now have 5100s but there are photos in my gallery of my duratracs at stock height.
  10. Dec 18, 2010 at 12:07 PM
    wtmtntaco
    wtmtntaco Well-Known Member
    NH
    03 TRD xtracab V6
    Bilstein 5100's at 2.5", Grey wire, Wheeler's 1.5 aal,
    I just put an old 265/75/16 worn bfg a/t on the spare rim in place of the 265/70 under my first gen and it fits, might just hang a little lower towards the front which is how I cranked up the cable. as far as the fifth dura trac, i decided on using an old tire instead of spending good money on a tire you really won't use unless you get a fifth matching rim. I love my dura-tracs....!
