dust in cab while parked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09 tacoma trd, May 9, 2009.
  1. May 9, 2009 at 6:23 PM
    09 tacoma trd
    09 tacoma trd [OP] Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    when i park on a construction site (it is very dusty place) i get dust on my dash and console while parked. people tell me that it is coming threw my air vent. but i thought the cab air filter would stop this. is there a way to stop this, or is there something else wrong.
  2. May 9, 2009 at 6:26 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Welcome to Toyota ownership! Enjoy your new ride!
  3. May 10, 2009 at 4:48 AM
    hoosiertaco
    hoosiertaco Well-Known Member
    Mine passes quite a bit of air through the door handles. Dust could come in through there.
  4. May 10, 2009 at 5:47 AM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    I have the same problem. Nothing you can do that I know of.
  5. May 12, 2009 at 2:48 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Do you have your vents closed, meaning the re-circulation is on instead of the outside air option? I take mine to the sand dunes and hardly get any sand/dust inside unless I open the windows :tumbleweed:.
  6. May 12, 2009 at 3:13 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    at work the parking lot is gravel. I had a dusty dash all the time with my tacoma, and even more with my 4runner now.
  7. May 12, 2009 at 5:30 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I have dust that comes in through the door handles too and the door seals.......dealer said that this was normal and nothing they could do about it.
  8. May 12, 2009 at 4:26 PM
    09 tacoma trd
    ontario, canada
    So what is the cab air filter for then?
  9. May 12, 2009 at 6:51 PM
    tdm156
    San Antonio, TX
    It just filters the cabin air when on recirculate from my understanding.
  10. May 12, 2009 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It filters the fresh air too. I havent found a vehicle out here (AZ) that gets no dust in the cab...
  11. May 12, 2009 at 7:00 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    It should be fairly easy to pull the door panels off and seal around the door handles better if that's an issue for you.
  12. May 12, 2009 at 7:07 PM
    tdm156
    San Antonio, TX
    Not an issue for me any more but was definately an issue when the dust clouds inside were getting as bad as the ones outside.
  13. May 12, 2009 at 7:54 PM
    Danzer
    Danzer Well-Known Member
    Derek
    Phoenix
    06 TRD Offroad 4x4 AT
    K&N 77 Series High-Flow Performance Kit.Rear Seat Covers.Rear TSB with 1.5" AAL and OME N182's. Front 5100's and OME 884's.Cobra CB.Painted mirrors, grill and powder coated rear bumper. Trail Gear sliders.
    Leave the recirculation on when you get to work that should close the vent. I've found that when driving down the road with the a/c off and the recirc. off you get a little breeze through the vent depending on where the setting is. I leave the recirc. on all the time when I'm not running a/c or heat because that little draft bugs me.
  14. May 12, 2009 at 8:27 PM
    Raven65
    Camden, SC
    Leaving the HVAC set to Recirc will certainly rule out that possibility, but when set to outside air, it comes in through the cabin filter, so I wouldn't think that would be the source of the dust. The door handles seem like a more likely possibility to me - but I'm totally guessing.
  15. May 12, 2009 at 8:35 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I used to work construction. Never had an issue with dust in the cab... But then again my cab was constantly dirty when I worked so I probably didn't notice. Haha
  16. May 13, 2009 at 8:01 AM
    hoosiertaco
    the cab needs some sort of fresh air exhaust when the fresh air make-up is used, this may just be where Toyota decided to put it. This is also why from the factory they want the recirc off and the A/C on in defrost mode. Constant turnover of dehumidified air in the cab. This aids in better defrostability.(hehe) I modded mine so I had the choice on what I wanted to do.:spy:
