dusty engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimiola, Sep 8, 2008.
  1. Sep 8, 2008 at 5:13 PM
    jimiola
    jimiola [OP] Member
    07 prerunner
    I was off in the dusty desert(ok Burningman)and now my engine compartment is dusty-can I just spray the engine with water to clean it off? I think it should be ok if I stay clear of the air intake.
  2. Sep 8, 2008 at 5:26 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yeah, its not a problem at all. just make sure you do it when the engine is cold to avoid causing damage to the block from rapid heat differential. i clean minecarefully with a pressure washer every once and a while, i just keep clear of electronic connections to avoid electrical system issues. keeps it looking like new under there.
  3. Sep 8, 2008 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the engine is "Hot" you can still clean it, just keep it running when you spray it. No differetn than driveing thru a stream or in the rain. Like mentioned above, keep clear of the pullies and electrical components. :)
  4. Sep 8, 2008 at 5:51 PM
    ERdept
    ERdept Well-Known Member
    I heard to cover the battery and either the starter or alternator. Need clarification on that.
    But when spraying water, use light pressure, not high pressure, so as not to get into wiring and electricals.
  5. Sep 8, 2008 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cover/avoid the Alternator. Battery will be fine, and the starter is pretty safe. :)
  6. Sep 8, 2008 at 6:14 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I have used a hose and spray nozzle at home on my past trucks and have never had a problem but agree to do it with the engine cool or if it must be done while warm/hot leave her running.
  7. Sep 8, 2008 at 6:49 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Instead of turning the dust to mud by spraying water on it, why not just blow the dust out with an air gun.
  8. Sep 8, 2008 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Id rather use a water hose. Compressed air can blow the dirt to where it shouldnt be. JMHO. Last time I used compressed air to clean my truck, I blew the buttons on the stereo INTO the stereo. :(
  9. Sep 8, 2008 at 6:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hose it off with the motor either cold, or while running...avoid the alternator, and intake if you have an open filter, and let the truck run a few minutes after you are done so it can dry it out. i usually hose mine off in the mornings before i crank it up, then run it a bit to get it dry.
  10. Sep 8, 2008 at 7:53 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Hahaha that's just awesome!!!
    Talk about an oh shit moment.
  11. Sep 8, 2008 at 9:47 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    A bit too much Psi there chris.
  12. Sep 9, 2008 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I know.......I seem to think if 130 psi is good for dusting the house, its good for cleaneing the truck. :D
