Dwill817's 1981 Toyota Pickup 4x4
Discussion in 'Other Builds' started by Dwill817, Oct 23, 2013.
  1. Sep 30, 2015 at 7:43 PM
    #281
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Nice! Are they just plastic?
    I just swapped out my driver's side the other day and now I can't get my fat ass between the seat and steering wheel. I don't think I can get much lower on the OEM seat sliders.
    [​IMG]DSC00065 by Jonathan K, on Flickr
    Dwill817[OP] likes this.
  2. Sep 30, 2015 at 8:07 PM
    #282
    Dwill817
    Dwill817 [OP] Well-Known Member
    Drew
    Alabama
    I didn't realize you had a first gen.. Still building the Tacoma?
    Yeah they're plastic. For $50 with harnesses I couldn't complain. They're molded real well to the shape of your lower back and butt so it sits nice.. Fiancé sat in them for awhile and gave the stamp of approval before I bought themso.. I'm straight lol
  3. Sep 30, 2015 at 8:15 PM
    #283
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I bought it a week and a half ago as my DD. But so far 'DD' has been 'Distraction Device' (from the Tacoma) rather than 'Daily Driver'. :oops:
    50 bucks? Yeah, can't argue with that. haha
    If they're decent enough for long trips I may have to go that or a similar route. Or a QD steering wheel.
  4. Oct 1, 2015 at 3:00 AM
    #284
    Dwill817
    Drew
    Alabama
    I haven't figured out when and how to mount these seats.. The interior floor needs cleaned up and bedlined or something cause it looks bad and I need to build a little stand to put these on the raise em up a few inches..
    I won't run harnesses until I get a cage for safety's sake, but I haven't figured out how to run them on an exo without going through the back of the cab or building a mini inside cage..
  5. Oct 1, 2015 at 3:26 AM
    #285
    Dwill817
    Drew
    Alabama
    Post some pics of that thing 45acp.. It looks real clean
  6. Oct 1, 2015 at 7:12 AM
    #286
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    It's an '81 as well. Overall great shape with the exception of small spots of rust in/on the bed and fenders.
    [​IMG]DSC00057 by Jonathan K, on Flickr
    Oh yeah, the rust that used to be the front body mounts. :laughing:
    [​IMG]DSC00062 by Jonathan K, on Flickr
    [​IMG]DSC00060 by Jonathan K, on Flickr
    I spent the weekend fabricating new sections of floor so the body mount issue is fixed now. The sound dampening material seems to hold moisture in, so I removed it and an air chisel makes quick work of it. I have plenty of roll-on bed liner and I was happy with the way it turned out in the Tacoma, so I'll be using it here too.
    If you're running an exo, I'd probably just weld a long piece of 1/8" or 3/16" thick plate along or under that reinforcement just below the rear window. That should be more than adequate support for anchoring harnesses. You could go so far as to run some plate or tabs on the horizontal brace of the exo hoop and use some bolts to tie that interior bracing to the cage. :notsure:
  7. Oct 1, 2015 at 7:22 AM
    #287
    Dwill817
    Drew
    Alabama
    Man that thing looks good.. I want another 100% stock one to put around town in. I think it would compliment this one perfect!
    I wanted to keep my stock and restore it and then I started riding and cared more about riding more than restoring.. I'll get another one day and keep it clean
  8. Oct 1, 2015 at 7:49 AM
    #288
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    The 84-88/89 models have the same body mount rust as a result of the windshield trim trapping moisture causing the pillars to rust and leak, and water soaks around the cab mount. I will have to fix my '87 eventually.
  9. Oct 1, 2015 at 7:50 AM
    #289
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Do it while you can! These things seem impossible to find unless you're up in the PNW. Based on what I could find currently and old for sale ads, these things have literally doubled in value in the last ten years. :eek: I'm sure it's thanks to the off-roaders drying up the market and destroying them on the trails. :oops:
  10. Oct 1, 2015 at 7:55 AM
    #290
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I haven't found any sign (so far) that I've had leaking around the windshield, but potentially the seal around the clutch MC. The insulation was a little damp around it and there is surface rust and peeling paint around the MC in the engine bay. Almost looks like they didn't fully prime the cab in its entirety before the base color.
  11. Oct 1, 2015 at 9:26 AM
    #291
    Dwill817
    Drew
    Alabama
    Mine done the same, but the only rust in the floor is right under the gas pedal and about a 1/2" x 6" hole right on the edge by the door and inline with the front seat mount..
  12. Oct 3, 2015 at 6:35 PM
    #292
    Dwill817
    Drew
    Alabama
    Got high steer on.. Pretty aggravating to get it all lined up perfectly, but I got it..
    Booyah!
    la0d0g, 45acp and Gear Head like this.
  13. Oct 3, 2015 at 6:35 PM
    #293
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Looks good dude!
  14. Oct 4, 2015 at 7:31 PM
    #294
    Dwill817
    Drew
    Alabama
    I reckon I'm gonna go to 14s in the front.. I'm getting like 7" of up travel and 5" down how the 12s are set up..
    I know I can redo the shock towers and get better travel but I think I can do a lot better with 14s..
  15. Oct 5, 2015 at 5:57 AM
    #295
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Just FYI I'm 28" to the frame and my 14's bottom out. And is only going to get worse when I lower it. Planning on going 12's up front and put the 14's through the bed in the back
  16. Oct 5, 2015 at 6:04 AM
    #296
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Is that normal up/down travel for leaf spring setups? I'm running 4 up/10 down... but with coilovers/links.
  17. Oct 5, 2015 at 6:43 AM
    #297
    ajohnson
    Andy
    Charlotte, NC
    FWIW I had the tall TG towers on my '85 and fit 14" shocks no problem. The fender well had to be cut open for those towers.
    The solid axle frames arch higher than IFS and Tacoma frames. I can't fit 14" with the same towers on my '87
  18. Oct 5, 2015 at 8:07 AM
    #298
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    I think he's just measuring what the shock is capable of at his current ride height, not actual travel. I'd be surprised if he's getting 7" of suspension up travel. My 82 moved very well and I was getting 4"-4.5" or so of up and that was with the spring going very negative
  19. Oct 5, 2015 at 9:53 AM
    #299
    Dwill817
    Drew
    Alabama
    I haven't cycled it yet.. I know I can't go up 7" for sure, but only having 5" of down travel on the shock will limit my down..
    For now I may just go redo the upper mount and keep the 12s..
    But at the same time, my buddy has 14s on his 1st gen and he fits them pretty good. He set his shock so that he runs out of uptravel and the springs are flat. I don't remember his uptravel though, like 4".
    I am about 1.5" lower lift than him, but I don't care if I have to cut the Inner fender up.
    Ideally I'd have 5" up and 9" down and bumpstop it there.
  20. Oct 5, 2015 at 9:54 AM
    #300
    Dwill817
    Drew
    Alabama
    I don't care if my springs go negative.. I can always build another pack if they wear out..
    GroundControl likes this.
