DYI Silver Color MatchPaint Job on CBI Trailrider Rear Bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AnotherSilverTaco, Jun 11, 2011.
  1. Jun 11, 2011 at 9:34 AM
    AnotherSilverTaco
    AnotherSilverTaco [OP] Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    I got my Trailrider in from CBI and worked all night to get it painted. What do you guys think?
  2. Jun 11, 2011 at 9:36 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i like it :thumbsup:
  3. Jun 11, 2011 at 9:43 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Very nice. What type paint and what was your process?
  4. Jun 11, 2011 at 9:54 AM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    I used Automotivetouchup.com They put the stuff in spray cans, send a couple of test cards for you to test the paint match before you commit. Apparently if the color is off they will fix it. I followed the instructions they give on the web site and it came out perfectly smooth and a near perfect match.
    I had seen enough rhino lined bumpers so I wanted to do something different.
    If anybody is serious about doing this let me know and I will give more details.
  5. Jun 11, 2011 at 10:24 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
  6. Jun 11, 2011 at 11:48 AM
    TheGreekIndian
    TheGreekIndian Well-Known Member
    More pictures?
  7. Jun 11, 2011 at 12:27 PM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    Is that with factory hitch or not. Really nice bumper.
  8. Jun 11, 2011 at 12:47 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    That turned out really nice. I would be interested in more pics of the bumper and the company you got the paint from. Curious if they can match pyrite mica for my fender flares.
  9. Jun 11, 2011 at 2:22 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    No that is not the factory hitch. The factory hitch hangs down way to much. CBI is good about getting max ground clearance with their bumpers. I should say that the way Nathan did mine is different from usual, because I plan to mount an M8000 with WARN multimount winch cradle as it would have been too short to put the pin in. Normally the hitch is cut at an angle for an even better departure angle, but Nathan realized that wouldn't work with the Warn winch cradle and he fixed it by making it square, so it looks a bit like stock. I am not sure exactly how much higher the bumper is from the stock setup, but I would say 3-4 inches higher for more ground clearance.
    Here is a pic of the hitch.
  10. Jun 11, 2011 at 2:40 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Just google automotivetouchup.com and search for your paint color.
    I will admit my paint job came out slightly lighter than the body, but I beiieve it was my fault and here is why.
    They tell you if a metallic paint is too light then paint thicker coats and if too dark paint lighter coats. It was 4 am and I was trying get it all done in 1 night, so I wasn't really paying that much attention to how dark or light it was. I also was cheap and only bought 1 can of clear coat.
    I my defense, light metallic colors from what I understand are some of the hardest to match.
    If you want to do a bumper. Buy 2 cans of primer, 2 cans of base coat and 2 cans of clear coat and use it all. Buy prep solvent, compound and eveything esle they suggest to use. Paint the inside of the bumper with rustoleum automative primer and enamal before doing the outside to save money. I did not seem to have a compatibility issue with the rustoleum and the touch up paint where they overlapped a bit on the edges. The paint will run 80-100 dollars.
    Sand like hell 80, then 120, and then 220 grit vibrating orbital sander. Use a little body filler for any deep scratches that might have occurred in shipping. Mine showed up off the pallet because the shipping company handled it so poorly!
    Here is a close up, so you can see what I mean.
    What amazes me is how smooth the paint came out.
    It is smoother than my factory paint with the exception of places that I could have sanded better.
  11. Jun 11, 2011 at 2:53 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Here is a close up of the light bucket, D shackle bracket, and I also had Nathan make a hole and bracket to mount my Warn Power cable for the winch. I also bought a front receiver hitch to mount the winch front and rear. The rough paint on the D shackle bracket is where I marred the paint when I failed to pad the 2x4 I used to pound the bumper into place. It fit nice and snug!
    I will try to post a pic with the winch in place. I bet it looks sweet.
  12. Jun 11, 2011 at 2:54 PM
    n0rth
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    Thanks for the info, turned out damn good for a one night paint job.
  13. Jun 11, 2011 at 3:05 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Yes, I felt like I took a risk trying to match the color and not sure if I could get the paint smooth with a spray can. They do put a nice spray tip on the spray cans. I had a few times when the paint spattered, but it dried smooth without a problem. I had to wet sand one single 1/4 inch drop of paint that splattered out of the tip. That was the only problem I had with the automotive touchup.com products.
    I would say to anybody to give the automotivetouchup.com paint a try. I was very impressed with how easy the paint went on.
    It is very doable.
  14. Jun 11, 2011 at 4:58 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    That's nice!!!!
  15. Jun 11, 2011 at 5:12 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Thanks for the compliments everyone, they beat the heck of the wife looking at it and saying, "huh, thats all you did!" I desperately need the validation.
  16. Jun 11, 2011 at 5:13 PM
    TheGreekIndian
    lets see some more angles of that bumper! Makes me wanna ditch this stock one asap!
  17. Jun 11, 2011 at 5:28 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Can't wait to get my CBI hidden front receiver hitch installed. Here is how it looks on the back.
  18. Jun 11, 2011 at 5:32 PM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    I had the chrome rear bumper with trailer hitch. I love the towing package for the auto transmission cooler, 7 pin, and all that stuff, but that big chrome thing just didn't go with the truck at all and that hitch was too low.
  19. Jun 12, 2011 at 12:53 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    that looks real good. Different is good. :)
  20. Jun 12, 2011 at 7:29 AM
    AnotherSilverTaco
    South Texas
    2006 Double Cab 4x4
    Dare to be different!
