Dying batteries
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Riotfunk, Nov 11, 2019.
  1. Feb 17, 2020 at 4:12 PM
    #61
    CanesFan95
    CanesFan95 Well-Known Member
    Florida
    Currently Shopping...
    I did a similar thing for my 2013 Accord. Stock, they come with these puny-ass little 51Rs. There's several parts you can get to fit in a 24F and that's what I've had ever since.
  2. Feb 22, 2020 at 8:11 AM
    #62
    oldmantaco
    oldmantaco Member
    2018 red Tacoma SR5
    none
  3. Feb 22, 2020 at 8:13 AM
    #63
    oldmantaco
    oldmantaco Member
    2018 red Tacoma SR5
    none
    On my 2018 SR5, first battery dead after 4 months, replacement dead 14 months later.
  4. Feb 22, 2020 at 9:36 AM
    #64
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    Follow up; I Swapped out the OEM battery with one I had laying around while waiting for the X2. After being on a trickle charge for 5 days, the OEM tested good for voltage and passed a load test.
    I haven't driven the truck much over the past several weeks so the battery must have drained down due to the parasitic draw from all the electronics.
    Thinking back, my trip meters reset to zero several times on start up during that period. Could be an indicator of low battery voltage.
  5. Feb 22, 2020 at 1:32 PM
    #65
    Deercamp
    Deercamp Well-Known Member
    Doug
    Seacoast area New Hampshire
    13 TRD Double Cab LB, Pyrite Mica
    Access Lite Rider Bed Cover, sill protectors, Weathertech mats, Wet Okole seat covers, de-badged, Plasti-Dipped Grill Emblem (black), LT 245/75/16 Goodyear Wrangler AT Adventure Kevlar tires
    My original battery lost its charge today. Tacoma Double Cab, (60,000 miles) has not been operated for a couple weeks and we have had cold weather. Battery is over 7 years old, as I bought Tacoma in January 2013. On a charger now, will see if it recovers. If not, off to Walmart. (I usually have good luck with batteries- still have original battery, which is now 12 years old, in 2008 BMW Z4.) I try to avoid short trips and use a battery tender on Z4, which is operated primarily in summer (16,000 miles.) Whenever I purchase a replacement battery, I put it on a trickle charger and do not install it before it is fully charged. (I got that tip from a Mercedes Benz North America executive who I used to ride with. He was a pretty good mechanic and we spent a lot of time riding BMW motorcycles in the farmlands of NJ back in the early 70’s. He was emphatic about having a fully charged battery before you install it.)
  6. Feb 22, 2020 at 2:19 PM
    #66
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    had mine go weak on me this week as I spent too long parked in the garage on the BT phonecall with the lights on. Next morning would crank for 1 sec then click click click. Had 12.45v but not enough needed a jump. Been fine since then.
  7. Feb 22, 2020 at 2:39 PM
    #67
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I live in Maine we just went through a spell of below zero weather even my diesel tractor started you have a parasitic drain somewhere when I leave for a week or more I put it on a trickle charger clock, memory etc but still day to day you have an issue. 4 years is about right for a battery no matter how cold it gets.
