Dying bird in my transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSurfer, Oct 11, 2014.
  1. Oct 11, 2014 at 9:32 AM
    TacoSurfer
    TacoSurfer [OP] Well-Known Member
    Central Cali
    07 Access 6-Speed 4.0L 4x4
    I've got this annoying squeezing chirp noise that is driving me nuts. It is going almost 24/7 but goes away immediately when I push the clutch in. Anyone have this before and know how I can get rid of it? Reminds me a bit of a squeaky belt but has to do with my clutch or something. Got some dealership extended warranty through February so if it's something driveline related I'm fully covered.
    Thanks,
    -Chris
  2. Oct 11, 2014 at 9:36 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You say it stops with the clutch in.
    Does it also happen in neutral with the truck stopped and the clutch out?
  3. Oct 11, 2014 at 9:38 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Throw out bearing?
  4. Oct 11, 2014 at 9:40 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    If it's covered bring it in. Sounds like the infamous throwout bearing.
  5. Oct 11, 2014 at 9:45 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  6. Oct 11, 2014 at 10:41 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    x 3+
  7. Oct 11, 2014 at 11:15 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Extras HP!!
  8. Oct 24, 2014 at 3:14 PM
    TacoSurfer
    Central Cali
    Sorry for the lag on response guys but does anyone know if a bad throw out bearing is covered under the power train warranty? IF not anyone know how much it costs to replace?
  9. Oct 24, 2014 at 3:31 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    this
  10. Oct 24, 2014 at 6:14 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Best to ask your dealer, but IIRC, several members have had theirs replaced under powertrain warranty. There is a TSB to follow for your '08 that involves replacing the slave cylinder, clutch release fork, as well as the bearing and likely the bellhousing as the integral guide stub wears.
    Out of warranty, then use the URD bearing and sleeve kit. Expect +- 6 hours labour if 4wd, a bit less if 2wd. May as well inspect the clutch well at the same time, and replace if needed.
    http://urdusa.com/store/product_info.php?products_id=1260519023
  11. Oct 24, 2014 at 6:28 PM
    bzzr2
    bzzr2 Well-Known Member
    If in warranty on powertrain still than you should be covered. Oherwise i agree with suggestion above. Mine did this, dealer replaced then it came back after a while, just not near as bad. Pretty common thing with these trucks.
  12. Oct 24, 2014 at 7:49 PM
    diverdriver64
    diverdriver64 Well-Known Member
    Kodiak Alaska
    05 Tacoma 4.0 V6 6Spd manual
    I had this same thing. 05 TRD 6 speed 130,000 miles. I bought the URD bearing kit and figured while I was having to have a shop actually touch my baby I might as well throw in a new clutch. Fixed the problem and then some : ) good luck with the warranty.
  13. Oct 25, 2014 at 6:43 PM
    TacoSurfer
    Central Cali
    Thanks guys. Ive got an appointment at the dealership wednesday for them to swap the seat belts and check the rear leaf springs both under recall. Ill do some more research on what else may need to be checked. Might as well have them do everything all at once!
  14. Oct 26, 2014 at 5:31 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    oh look another person with a messed up 6sp TOB....
    *puts the his auto in D and drives off*
