Dynamat extreme, Dynapad or Dynaliner on floors
Discussion in 'Audio & Video' started by 20tacoma17, Jul 2, 2017.
  1. Jul 2, 2017 at 6:11 PM
    20tacoma17
    20tacoma17 [OP] Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I've already installed dynamat extreme on all door skins, panels and behind rear seats. Now I want to tackle the floor. Trying to decide which is best of the 3 in title? Ive read that the best way is dynamat and dynapad but only want to use one. Anyone have any experience on which would work better for road noise? Thanks
  2. Jul 3, 2017 at 7:34 AM
    su.b.rat
    su.b.rat broken truck
    also interested. I've got dynamat in and out all the doors and behind the seats, and the power I'm running resonates the floor, go figure. hopefully I'll get to this before I'm dead.
  3. Jul 3, 2017 at 7:59 AM
    20tacoma17
    2017 DCLB Sport AT
  4. Jul 4, 2017 at 1:44 AM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    Incorrect.
    Google sound deadener showdown.
    You want cld, then ccf, then mlv.
  5. Jul 4, 2017 at 5:23 AM
    20tacoma17
    2017 DCLB Sport AT
    Not gonna spend that kind of money so I'm just doing one. Whichever is best for the floor.
  6. Jul 4, 2017 at 5:53 AM
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    I used Dynamat in the doors, roof, and rear wall but went with the Dynapad in the floor for 2 reasons. First, it contains MLV vinyl which provides the best noise reduction and it made a huge difference in my truck. Second, it does not have to be glued down which makes for a much easier installation and allows access to the floor for any service needs in the future as there are many plugs for access spots on the floor. Dynapad already has 2 layers of foam above and below the vinyl so it is truly a one step process. Hope this helps.
    ocscott likes this.
  7. Jul 4, 2017 at 5:54 AM
    20tacoma17
    2017 DCLB Sport AT
    It does.
    Did you remove stock padding?
  8. Jul 4, 2017 at 5:56 AM
    skyking3
    Tom
    No, not at all. I installed it between the stock padding and carpet. Easy peasy.
  9. Jul 4, 2017 at 5:58 AM
    20tacoma17
    2017 DCLB Sport AT
    Thanks
  10. Jul 5, 2017 at 6:45 PM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    the Dynapad will be best then.
  11. Jul 5, 2017 at 7:32 PM
    20tacoma17
    2017 DCLB Sport AT
    Thanks, I figure if I put pad down from the firewall all the way back will help with some road noise.
  12. Jul 5, 2017 at 8:59 PM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    You only need 25% coverage of the dynamat on the floor.
    I highly recommend you do that if you are gonna take the time to do the other stuff.
  13. Sep 14, 2017 at 5:05 PM
    TacoTuesday89
    TacoTuesday89 Member
    2016 Tacoma TRD OFFRoad 4x4 DCSB Quicksand
    what size dynamat should I buy for the behind the seats?
  14. Sep 15, 2017 at 7:25 PM
    skyking3
    Tom
    I used 13 square feet behind the rear seats so you could just order the 12 square feet door pack if that is the only part you plan on doing.
