DynaMat or Mastic Tape
Discussion in 'Audio & Video' started by Turdsport, Sep 24, 2015.
  1. Sep 24, 2015 at 10:47 AM
    Turdsport
    Turdsport [OP] Well-Known Member
    Josh
    '14 TRD Sport Supercharged
    All of the HVAC guys out there knows what mastic tape is. You better be sure you want it taped up before you commit! I'm just curious if dynamat, or the like, is anything similar to mastic tape. seems like it is at first glance.
  2. Sep 24, 2015 at 2:59 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    A quick google search shows mastic tape is made of Ethylene Propylene Rubber, whereas products like Dynamat Xtreme and RAAMmat are made of Butyl rubber. Both have similar thickness, 60 butyl vs 65 EP. Butyl is widely used in the construction of subwoofer surrounds. Doesn't seem like there's much difference other than having to spend a lot more time cutting the tape and some additional weight due to thickness of the tape.
  3. Sep 24, 2015 at 3:22 PM
    Turdsport
    Josh
    Kinda what I was thinking. I can get the tape for a good bit less than the dynamat. Might give it a try one day.
  4. Sep 24, 2015 at 5:47 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    if 125$ shipped for 40 SQ feet is in ur budget for Really good deadener i still have the Shok deadener on Group buy.
    Let me know or post in the thread if its of interest
    TxStVanWilder likes this.
  5. Sep 27, 2015 at 1:12 PM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    I just ordered a bulk 36 sq. ft. pack of Dynamat Xtreme on Amazon for $150. Use what all the pros use....there is a reason almost all high end shops use Dynamat products. Just my .02 though.
  6. Sep 27, 2015 at 2:40 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Ill stack up the Shok deadener against Dynamat extreme any day :), for those that recognize that are more than happy with the Shok and ill gladly supply them :)
  7. Sep 27, 2015 at 3:53 PM
    EasyLivin
    Jeff
    Euless, TX
    Sorry, no disrespect meant on that. I'm sure your product works great! I have had quite a bit of success with Dynamat in the past. Just based on my experiences!
  8. Sep 27, 2015 at 4:26 PM
    Revelations
    2014 MGM DCSB
    I bought the same amount of RAAMmat for $120 shipped. Very comparable products. I've used Dynamat Xtreme and it's a good product. It's a bit less messy, but the cost is a bit higher.
  9. Jan 16, 2016 at 10:17 AM
    Yigs
    Yigs New Member
    What about SecondSkin audio? I have seen a few discounts posted around the holidays, 25% off if I remember correctly. Also, what would you recommend to reduce the noise of panels squeaking or rubbing against each other? Ya know, that subtle "eee eee eee" as your drive.
  10. Jan 16, 2016 at 11:14 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    You can take a look at my group buy in my sig. I have maybe 1 or 2 packs left for the next 6 weeks or so
