Dynamat Speaker Kit
Discussion in 'Audio & Video' started by Femino, Apr 27, 2011.
  1. Apr 27, 2011 at 8:23 AM
    Femino
    Femino [OP] Member
    Boston, MA
    SR5
    Hi All,
    I am getting a new HU (Alpine CDE 126BT) and 6x9's (Pioneer TS-A6964R) for the front doors, from Crutchfield. Speakers will be running directly of HU (18 RMS) with no extra amp.
    Crutchfiled sugessted the Dynamat 10"x10" Speaker Kit. Has any one used it? What were your results? Where/how did you install?
    I'm a rookie at this stuff, but it seems that a 10x10 sheet would do very little. I would think you would need to insualte the entire door. I'm not looking to win any comps, and i dont feel like spending an extra $180 for the entire door. The speaker kit is only $26, and I'd certainly consider if it is effective.
    Thanks
  2. Apr 27, 2011 at 9:15 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    It is effective, but all it will do is stop the outer skin from vibrating.
    Do some reading at www.sounddeadenershowdown.com
    Your most effective, cheap solution would be to put a bit on the outer door skin to reduce resonance from that panel. Then get some thin metal or mesh, rivit or screw it to the door to cover any holes, then cover those with deadener, effectively make a "box" out of your door, and killing vibrations at the same time.
    You dont need 100% coverage, dont let that myth get you.
    Good luck!
  3. Apr 27, 2011 at 9:21 AM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    Talk to rick at raam audio he will set you straight don't go with dynamat its all the same shit but his is cheaper
