Dynamat vs Second Skin
Discussion in 'Audio & Video' started by LonghornTaco, Nov 8, 2008.
  1. Nov 8, 2008 at 5:05 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Thinking of another mod... Putting down sound dampening material in the cab of my truck - floor, back wall, doors, roof.
    I read this post about the pros and cons of the different types of materials and why (http://www.sounddeadenershowdown.com/) but I was wondering if anyone had done the entire cab and whether or not it was worth it? And how many sq ft did you use?
    And I can see that Second Skin and Dynamat are probably the front runners for quality, but secondskinaudio.com doesn't come up. Are they still around?
    I can get 72 sq ft of Dynamax Xtreme for about $260 on ebay, but was curious about second skin...
  2. Nov 8, 2008 at 6:22 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    I run Second Skin and love it. Both products are great but I think SS is a better value and has a thicker foil backing. As for doing the entire truck, yes do the works but make the floor the last thing to do. The floor is better left to a sound absorbing pad rather than a dampener, SS make that as well but the name escapes me at the moment. I recommend in this order for deadening: doors, door panels, backwall, roof for best results. Again the floor is the last thing that should be done IF you use deadener only.
  3. Nov 8, 2008 at 6:28 PM
    LonghornTaco
    Minnesota
    Thanks! That is the same order that I gathered from reading a bunch of posts...
    When did you do yours? Did you do the entire cab? Do it yourself? Any pics of the install?
    Any idea if second skin is still around? Their website is down...
  4. Nov 8, 2008 at 6:45 PM
    LonghornTaco
    Minnesota
    And what kind of "sound absorbing foam"? Is it like the ensolite stuff from RAAMAudio?
  5. Nov 9, 2008 at 6:36 PM
    Coheednme13
    Coheednme13 Well-Known Member
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    I have done the entire cab but only a reg cab. I used Raamat for deadening but I know that SS makes great stuff I would always trust them. They are still alive and well their site must have just been down. As far as the mat goes you can use ensolite or SS's version is overkill and if you want the ultimate sound insulation go with SS's luxury line pro. It is about a half inch thick with foam and a vinyl constraining layer. Great stuff.
  6. Nov 9, 2008 at 6:52 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    where exactly do you put it in a reg cab?
  7. Nov 9, 2008 at 6:56 PM
    Coheednme13
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    Put what? Deadener or Luxury Liner pro
  8. Nov 9, 2008 at 6:56 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    sound deadener
  9. Nov 9, 2008 at 7:35 PM
    Coheednme13
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    I have done the back wall, floor, roof, and side walls behind the doors. I will do the doors soon but I have to order more deadener. I have used a roll and a half or about 100 sq feet. I am going all out some spots 5 layers. Everywhere there is at least 2 layers. I am thinking of doing audio competitions so I want it to be DEAD!!. Oh yeah I am doing the body panels such as a pillars, kicks, plasitc panels on side walls and the rib along the back wall to keep the panels from rattleling.
  10. Nov 9, 2008 at 8:19 PM
    LonghornTaco
    Minnesota
    I hope their site comes back up so I can check them out. I've heard good things about Second Skin and they are cheaper than Dynamat.
  11. Nov 10, 2008 at 6:20 AM
    Coheednme13
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    It is a large undertaking it is not a fast process. Applying the deadener is easy the time consuming part is taking off the body panels and finding another car to drive while all the seats are out or just keep putting the seats in and out. I have a bench so I have to take it in an out but if you have a double cab you can just put back in one seat to drive. I have just been driving my brother's old toyota truck
  12. Nov 10, 2008 at 6:49 AM
    LonghornTaco
    Minnesota
    How long did it take you (considering that you did 5 layers...:eek:)?
    I was planning to do it in stages:
    Do the doors, drive to work.
    Do the back wall, drive to work.
    Do the roof, drive to work.
    Do the floor (over the weekend), drive to work...
  13. Nov 11, 2008 at 9:37 AM
    Coheednme13
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    It took be about 3 days of working a few hours each night to do the back wall and back floor section and 3 hours to do the front floor but this mutiple layers. I only have 5 layers in one spot and 3 and in many but at least 2 everywhere. Some areas especially around the transmission area that are really dead. I did my roof with two layers and luxury liner pro in 3 hours or so
  14. Nov 11, 2008 at 1:52 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    how many rolls of RAAMmat did you order to get that many layers?
  15. Nov 11, 2008 at 2:21 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I used FrostKing. $15 for 15sqft. Deadened the road noise, reduced vibrations, increased stereo volume and the cab gets warm QUICK!
  16. Nov 11, 2008 at 5:47 PM
    Coheednme13
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    I'm not totally done yet, but it has taken me 1.5 rolls of Raammat I got ensolite also but haven't used any because I decided to go with Second Skin Luxury liner pro. Really thick stuff does an awesome job. I must plug Raammat it is great. I didn't get cut at all from the foil and it is extremely flexible and easy to work with. I'm not sure if there are any threads on here about how to deaden but I will be more than happy to make one or answer any questions.
