Dynamic Radar Cruise Control default following distance
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TFly, May 8, 2018.
  1. May 8, 2018 at 1:51 PM
    TFly
    TFly [OP] Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Any way to change the default distance? I might use it more often if it was defaulted to the nearest setting instead of the farthest. I was able to change several other system defaults with Techstream, but couldn't find one for the dynamic cruise.
  2. May 8, 2018 at 3:17 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    From the manual:
    Chew likes this.
  3. May 8, 2018 at 3:27 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I have mine set on long using the button on the steering wheel, on my 18 SR. I have to use my key to unlock the door (no remote on base model), but I have dynamic cruise control :D
    My salesman went over it with me. Yours didn't?
    Mark77 likes this.
  4. May 8, 2018 at 3:41 PM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I understand how to change it. It resets to the farthest setting every time you turn off the truck. What I want to know is to how to get it to DEFAULT to the closest setting.
    MountainManGuy and Trousers like this.
  5. Dec 23, 2020 at 5:59 AM
    Trousers
    Trousers Well-Known Member
    NW FL
    2021 Limited 4x4 Wind Chill Pearl pavement princess
    Blast from the past. I feel ya OP. It would be great if there was a setting in the menu to make it default to the shortest distance. The long distance setting is obnoxious. I would prefer to not have to cycle thru long-medium-short every time I use DRCC.
    MountainManGuy and kbow12A like this.
  6. Dec 23, 2020 at 6:08 AM
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I would also like to disable the “target acquired” graphic that pops up and blocks the entire display every time a car goes in and out of radar range. Is this possible?
    IndyTac, Trousers and LstMinutePanic like this.
  7. Dec 23, 2020 at 6:23 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    :sadviolin::rimshot:
    Trousers and Chew like this.
  8. Dec 23, 2020 at 6:47 AM
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Pretty sure that's possible from the settings menu on the display. I disabled that and the full screen gear shift indicator. I don't have access to my truck right now so I can't pull it up right now.
    Trousers likes this.
  9. Dec 23, 2020 at 6:48 AM
    BadDogMax
    IdahoLand
    2019 TRD Pro
    Christmas music? How sweet!
    IndyTac and TRD-ED[QUOTED] like this.
  10. Dec 29, 2020 at 3:59 PM
    danwray
    danwray Traitor
    Dan
    Kentucky
    I apologise, apparently I did no disable this, I guess I just got used to it to the point that it didn't bug me anymore.
  11. Dec 29, 2020 at 4:14 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    You just need to press the button 2x to change to the shortest follow distance. Not the hardest thing to do and a small price to pay to have radar cruise control offered standard. My $45k Audi doesn't even have radar cruise control.
    FreidasBoss likes this.
  12. Dec 29, 2020 at 4:18 PM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    You should be able to set the default. Why does it revert? It's like the etc button. Why does it revert every time you turn off the truck? What it should do is just remember your last used setting on stuff like this. I bought the etc always on adapter because it's annoying to have to press it every time.
  13. Dec 29, 2020 at 4:39 PM
    Kairide
    2020 White SR5
    It's not a physical button that controls the setting, it's an electronic one...if that makes sense. In my Tesla, the follow distance is set on the stalk by turning to my desired distance of 1 car and that's the default. Similar to how the intermittent windshield wiper speed is set physically and stays. The follow distance in the Tacoma is an electronic setting that resets when the engine is turned off. I'm assuming it's because there's no memory set up for the function. Again, this is a main stream mid-size pick up, not a luxury car.
