Dyno results are in!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jepaton, Feb 3, 2012.
  1. Feb 4, 2012 at 7:33 PM
    #101
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :thumbsup:
  2. Feb 4, 2012 at 8:35 PM
    #102
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The 6spd manual like the OP has is 1.00:1 in 5th gear, and should be dyno'ed in 5th.
  3. Feb 4, 2012 at 8:41 PM
    #103
    Order66
    Order66 Four Wheel Drive With Room For Five!
    Nick
    Georgia
    88 4Runner SR5 V6
    3 inch body lift, 33x12.50x15 Pro Comp A/Ts, Front and Rear Tube Bumpers
    Nice, man. Like a bowse. :burnrubber:
  4. Feb 5, 2012 at 12:58 AM
    #104
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Now that my truck is paid off and I am now single I plan on boosting the shit outta this thing... safely of course :).
  5. Feb 5, 2012 at 5:41 AM
    #105
    Jepaton
    Jepaton [OP] Well-Known Member
    Josh
    NC
    10 TRD Sport SR5
    K&N CAI, Magnaflow true dual exhaust, Air Raid Throttle body spacer, TRD Supercharger, Wet Okole seat covers, and great audio
    Thanks for the info on that
  6. Feb 5, 2012 at 7:11 AM
    #106
    Jepaton
    Josh
    NC
    10 TRD Sport SR5
  7. Feb 5, 2012 at 7:20 AM
    #107
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
  8. Feb 7, 2012 at 11:03 AM
    #108
    Jepaton
    Josh
    NC
    10 TRD Sport SR5
    Dyno from monday, post the pic/video when wife gets back with camera, but till then, 310 rwhp in forth, 303 and 305 rwhp in fifth. Hot run unfortunately didn't have time to cool down before but either way three runs ranging from 310 to 342 rwhp. Oh and found out the corrections factor for all of these was SAE .92 Thanks for all the good comments and advise, keep a look out for all the new mods to come.
  9. Feb 7, 2012 at 1:34 PM
    #109
    Blasphemous
    That seems more correct to me.
  10. Feb 7, 2012 at 3:27 PM
    #110
    MaloneS
    MaloneS Well-Known Member
    Steven
    The Woodlands, TX
    Sold, but going to by another
    :popcorn:Love to see the numbers on the track!
  11. Feb 7, 2012 at 3:28 PM
    #111
    Aw9d
    Aw9d That one guy
    Same here. But I'm not telling myself I don't need one. It's the wife telling me "you don't need a super charger, I need a track bike"..
  12. Feb 9, 2012 at 12:35 PM
    #112
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you took your truck to a DynoJet dyno, and did some runs with the same mods, I bet you would be about 315 whp.
    Due to differences between Eddie current Mustang Dynos and Inertia Dyno DynoJets. They usually take much higher HP output of a vehicle to have a more equal reading between the two.
  13. Feb 11, 2012 at 6:39 AM
    #113
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Thanks Tor! I've been reading up on the dyno jet vs the mustang dyno and most people say that the dyno jets will result in higher rear wheel numbers.
    Decent explanation of a dyno jet 248C vs. mustang md-250 <(this is the model I ran my tacoma on)
    http://maximumperformance.biz/Dyno_Simple.htm
  14. Feb 13, 2012 at 7:11 AM
    #114
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Agreed,
    Typically an auto trans is a about 15% loss, being a manual it will show a bit more output, that much though, doubtful.
  15. Feb 27, 2012 at 1:30 PM
    #115
    Jepaton
    Josh
    NC
    10 TRD Sport SR5
    Recomend if anyone else puts the supercharger on that they upgrade the clutch. HAHAHAHA Had fun burning the stock one out. Anyways Clutch Masters stage 3 on today
  16. Feb 27, 2012 at 2:05 PM
    #116
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    The dealership must install it and install the TRD flashed tune.
    If you mess with the pulley for more boost or mess with the tune your warranty is voided.
    How are they reprogramming the ECU? I though they were not programmable save for an entire reflash (which would be a bitch to tune).
    Adding the meth kit would also void your warranty.
    Your numbers do seem quite high on the TRD SC and TRD flash. I have the exact same kit and I am pretty certain I am not 340 to the wheels, 300 maybe.
    ***EDIT***
    Just saw your 310 RWHP post...that seems more to the norm.
  17. Mar 17, 2012 at 11:00 AM
    #117
    Jepaton
    Josh
    NC
    10 TRD Sport SR5
    They can't reprogram the ecu, I have to install a piggy back.
    And the 310 was the only dyno done on a dynojet the other two were done on a mustang dyno which are known to be higher I've found out.
  18. Dec 19, 2013 at 8:45 AM
    #118
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    my brain hurts.....
    what have we come to here on numbers?
    342 sounds extremely high......
    somebody?
  19. Dec 19, 2013 at 8:53 AM
    #119
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He explains it some previous posts. It was between 303-310.
    Someone on the mustang dyno, most likely didn't set it up right. They read lower than DynoJet, for the most part
  20. Dec 19, 2013 at 9:33 AM
    #120
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    havent slept yet, and i kinda breezed through this mess
    thanks Torq!
