Dyno test experiment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ResidentCarbon, Oct 28, 2019.
  1. Oct 28, 2019 at 1:17 PM
    ResidentCarbon
    ResidentCarbon [OP] Guest
    I've scheduled a dyno test that I will live stream via my YouTube channel Spartan ADV. The test will put to bed two different topics: ACIS disconnect and K&N filters vs stock. The test will be long and uninterrupted (hopefully). Nothing will be monetized, all costs will be mine alone, and this experiment is solely for the benefit of the community, nothing more. There is no need to subscribe my channel, just watch the video or view results. More information shortly. The test is going to be November 9th of this year unless otherwise notified. https://www.youtube.com/channel/UCs081A0r78MDGWNWuYYYvuw
  2. Oct 28, 2019 at 1:23 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Link to channel?
  3. Oct 28, 2019 at 1:28 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Thanks for doing this. Post the 3.5L engine description PDF of ACIS if you get a chance. This very clearly shows the valve and its function. I will post later today, if you can't get to it. Thanks
  4. Oct 28, 2019 at 1:29 PM
    Trucknorris
    Trucknorris Well-Known Member
    2017 sr5 double cab 4x4
    Several
    Following
  5. Oct 28, 2019 at 1:30 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note, someone did a dyno test about a year ago. They tested both the stock filter and no filter. There was no change in the dyno output.
    I'll see if I can find the thread.
    Here it is:
    https://www.tacomaworld.com/threads/2016-dyno-test.539231/
  6. Oct 28, 2019 at 1:30 PM
    ResidentCarbon
    Thunder Fist[QUOTED] likes this.
  7. Oct 28, 2019 at 1:30 PM
    ResidentCarbon
    I know there isn't, but this will include the ACIS as well.
    GillyLink and tonered[QUOTED] like this.
  8. Oct 28, 2019 at 1:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cool. I edited my post above to add the link.
    :cheers:
    ResidentCarbon[OP] likes this.
  9. Oct 28, 2019 at 1:53 PM
    Xwelder
    Xwelder Active Member
    I just tried this on my truck for the commute home. I have OV Tune, primarily to fix what I believed was either the transition from Atkinson to otto or an issue with the torque converter slip our trucks have. OV had made it much better, but unplugging the ACIS took every bit of stutter out of my truck. I did notice a bit less power above 5000 rpm, but not much, and since I am rarely in that range, I don't care. I am curious if @bshammer0 will give this a try. His description of the "stutter" most closely sounded like what I had going on. The real test for me will be if I can run 87 octane. My stutter was always more pronounce with lower octane gas.
    tonered likes this.
  10. Oct 28, 2019 at 1:54 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Does it throw a CEL?
  11. Oct 28, 2019 at 1:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Have you tried the 2.0 Betas? They were very smooth and linear from idle to redline. Although no release notes were given, it was said that the Betas had the revised ACIS code.
  12. Oct 28, 2019 at 2:19 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I may indeed try that at some point, but I'm running the stock B04 right now pending final 2.0 OV release, and the stutter isn't an issue with my truck on 93 octane. Ever. Any time I've run 87 octane stock or tuned (though less when tuned) there's been a stutter that feels like a slight miss feeling so I've just stuck w/ 93 and haven't felt a stutter in a very long time. Sorry I can't be of more help.
    Taco16LB and tonered like this.
  13. Oct 28, 2019 at 2:20 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Subscribed.
  14. Oct 28, 2019 at 2:25 PM
    sebooher95
    sebooher95 Well-Known Member
    Mississippi
    ‘18 MGM Sport 6MT 4x4 KDMax6.0 XT
    KDMax6.0 XT Tuned
    Nope. Have had mine unplugged for a couple days now
  15. Oct 28, 2019 at 2:31 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Question...
    I've heard your supposed to disable traction control when doing dyno pulls or bad stuff can happen.
    Is it a legit concern?
  16. Oct 28, 2019 at 2:32 PM
    ResidentCarbon
    Boghog1[QUOTED] likes this.
  17. Oct 28, 2019 at 2:34 PM
    ResidentCarbon
    No idea. I'll look into that. I wouldn't think so as this isn't for tuning purposes, but I'll look into it.
  18. Oct 28, 2019 at 2:39 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    You’ll pick up 4-5 horsepower in the midrange and lose it at redline so the dyno will record a zero gain.
  19. Oct 28, 2019 at 2:39 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Thanks for this. Where are you located?
    GillyLink and ResidentCarbon[OP] like this.
  20. Oct 28, 2019 at 2:41 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    For the Dyno test are you going to take into consideration Density Altitude / corrected elevation during back to back dyno pulls ??
