Dyno test experiment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ResidentCarbon, Oct 28, 2019.
  1. Oct 28, 2019 at 2:41 PM
    ResidentCarbon
    ResidentCarbon [OP] Guest
    I will also add test parameters to view normal driving for daily and the lead foot variety. As stated, I want to be as comprehensive as possible. I will list the fuel used and where it came from.
    TN
  2. Oct 28, 2019 at 2:44 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I was just wondering if you dyno tested an Ovtuned truck plugged and unplugged, what the difference might be.
    ResidentCarbon[OP] likes this.
  3. Oct 28, 2019 at 2:44 PM
    ResidentCarbon
    Being that all the testing will be on the same day, those aspects won't matter as your ecu works with the O2 sensors to account for those changes and keep the truck running at optimal performance. But I can post those as well. They are issues for carburetors and O2 sensor delete engines.
    US Marine[QUOTED] likes this.
  4. Oct 28, 2019 at 2:48 PM
    ResidentCarbon
    No, this will be a stock engine. Being that a tuned ecu has changed parameters, I'd caution from this type of testing on that end. Now, if this does yield any gains, it would lend to new tuning options for OV. This is simply a "myth buster" style test on a stock engine.
    Chew, US Marine and Tullie D like this.
  5. Oct 28, 2019 at 4:17 PM
    Chief 4x4
    Chief 4x4 Well-Known Member
    Tim Dean
    Mississippi
    2017 TRD 4WD
    TRD GRILL WET OKLOE SEAT COVERS RAPTOR GRILL LIGHTS NEW OFF ROAD BED DECALS SCS Ray 10'S 16x8 Gunmetal OVTune
    Following.
    GillyLink likes this.
  6. Oct 28, 2019 at 4:49 PM
    Xwelder
    Xwelder Active Member
    nope, not yet
    Skydvrr[QUOTED] likes this.
  7. Oct 28, 2019 at 4:54 PM
    Xwelder
    yes, I've tried them all and am currently on 19800 and it has really made my truck drive better in all aspects. but I still couldn't run 87 octane without a lot of stutter. The stutter was still slight on 93, but non-existent with the ACIS disconnected
    tonered[QUOTED] likes this.
  8. Oct 28, 2019 at 5:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hopefully the full version will make it right.
    :cheers:
  9. Oct 29, 2019 at 12:54 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Is the ACIS normally open or closed with the engine off?
    According the the pdf on this motor, when it is closed, it provides better power in the low rpm range with medium and high load (initial take off, 2nd gear low rpm, up hill). And opens when in all other conditions (high rpm high load, low rpm low load)
    So if unplugging it leaves it closed all the time, that tells me it will benefit everything except high rpm pulls and low rpm cruising.
    I personally can't stand that stutter and jumpiness and would be willing the loose some top end power for smoothness. I may try it.
  10. Oct 29, 2019 at 5:51 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    If I remember my simplified engine airflow studies (from years ago) you want long intake runners during low RPMs and short intake runners during high RPMs. It would stand to reason that if the "Motor" is Closed at low RPMs then "Closed" means "in the condition of having long intake runners". Do I have that correct?
  11. Oct 29, 2019 at 5:56 AM
    Brofessor
    Brofessor Well-Known Member
    Too much variation on dynos (on the same exact vehicle), to try and gauge the benefits of an air filter.
    Won’t be very accurate, I’m afraid...
  12. Oct 29, 2019 at 6:06 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    You are correct.
    Tacorific[QUOTED] likes this.
  13. Oct 29, 2019 at 8:09 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    Well I for one will be watching the game of the year on the 9th, but I am interested in the results....;)
    gurneyeagle, CXYyuppie and PapaRee like this.
  14. Oct 29, 2019 at 10:48 AM
    VoodooPro
    VoodooPro Well-Known Member
    2019 Voodoo blue TRD Pro
    OV 93 tune, TRD pro intake, LED headlights, LED interior lights, tuffskinz interior overlays "RCF", tailgate inlay, Illuminated kickplates, blue interior compartment inlays. Painted voodoo blue interior trim, nitto ridge grapplers, bara 1 inch spacers, redline pro hood struts, trd oil and radiator caps.
    Matt at OVtune needs to tune the Atkinson cycle out entirely. That nonsense never caught on because its complicated, expensive, and has little benifit. It's like the rotary. If it was any good most cars would be Atkinson not otto, as it was invented in the 1880s. This is clearly just an ignorant PR stunt to appease the asshat hippies over at the EPA. Without going TT there is pretty much no other way you can get MORE fuel efficiency from a 3.5L NA V6 without sacrificing something. Read up on why Atkinson engines werent adopted. It's very similar to the rotary. More complex, more expensive, more maintenance, and less powerful. Just make it so it runs in the otto cycle indefinitely, problem solved.
    I wouldnt be shocked to see some pretty goofy and inconsistent dyno runs on this 3.5 as its prime directive is to be as efficient as possible. Hense why stock ones run terrible, since the toyota engineers thought making its transmission fight to keep 1200 engine RPM at all cost, was more important than drivability/safety and driver confidence.
    Superdave1.0 likes this.
  15. Oct 29, 2019 at 2:56 PM
    #35
    92ehatch
    Kinley
    Hendersonville NC
    Im going to update this with my experience today. I read this post/and the one in the what did you do today thread at 3 am. When i left for work at 4 am i opened the hood, unplugged the connector and drove to work.
    My commute goes straight through downtown, stop and go at red lights before hitting the interstate.
    Shift from 1st to second (MT) is smooth as hell. The rev through first to 4k is flawless, the 3500rpm surge is completely gone. Accelerating up hills no longer has that lunge to it. Rev hang seems to be completely gone below 5k, Above 5k it is still there slightly but not nearly as bad.
    Before in 6th at 60-70 on the interstate, accelerating up a hill, it would lunge a bit, almost like a misfire, This is gone completely.
    On my commute home, i took a different route, one that i knew would have stop/go, accelerate, decelerate.
    I can tell you that this was the best the truck felt. Every shift was smooth. I could rev up to 4k without a surge, shift to 2nd or 3rd with no problem. Revs fall quickly, revmatch on downshift seemed better as the throttle response was better. This however is still not perfect as throttle by wire is inherently slower. Also, the low gas pedal is a bitch.
    I like to take off from a stop on downhills in second gear, because lazy. Before, this would buck, lunge, surge, it was horrible. Today, perfect, no problem at all.
    I do feel like i lost some top end power, above 5k, but i dont care if i lost 50hp/tq at this point, its freaking smooth, i enjoyed my commute today much better. And how often are you flat out to redline anyways?
    I just need a couple of block off plugs to keep the wires from corroding away. Thanks OP. Cant wait for the dyno results
    Need to do my accumulator hack to make the best of this.
    (My commute is 18 miles one way, through stop, go, cruising, interstate and hwy)
  16. Oct 29, 2019 at 3:03 PM
    #36
    su.b.rat
    su.b.rat broken truck
    what are you running? stock ECU calibration? OVT/version? any exhaust etc?
    shakerhood likes this.
  17. Oct 29, 2019 at 3:04 PM
    #37
    92ehatch
    Kinley
    Hendersonville NC
    completely stock, nothing has been modified. No OV tune, no ADM, no exhaust, no intake. 100% stock
    GillyLink and su.b.rat like this.
  18. Oct 29, 2019 at 3:05 PM
    #38
    su.b.rat
    do you by chance know your ECU calibration?
    Pablo8 likes this.
  19. Oct 29, 2019 at 3:07 PM
    #39
    92ehatch
    Kinley
    Hendersonville NC
    no, Its a 2019 that i bought in may. Manual Trans, so there are only like 2 options i think.
    su.b.rat likes this.
  20. Oct 29, 2019 at 6:01 PM
    #40
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
