Dyno Time Booked, Need ignition/tach/rpm signal
Discussion in 'Performance and Tuning' started by dragon, Aug 22, 2014.
  1. Aug 22, 2014 at 9:38 AM
    dragon
    dragon [OP] Well-Known Member
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    Hi guys,
    I have my taco booked for some dyno runs with a local car club.
    Just trying to do some research beforehand to save some time on the rack.
    Where's the best place to pick up the ignition or tach signal?
    The truck in question is a trd supercharged 2008 Toyota Tacoma double cab long box sr5 4x4.
    Thanks in advance.
  2. Aug 22, 2014 at 9:39 AM
    dragon
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    The dyno machine is a Dynojet 224XLC, if it matters.
  3. Aug 22, 2014 at 7:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    wont they pull it from the OBD2 port?
    got a wideband bung already ?
  4. Aug 23, 2014 at 4:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Depending on which side of the truck that their computer is on, driver side or passenger side coil-pack wires. I have always used #5 cylinder's. Passenger, closest to the firewall.
  5. Aug 24, 2014 at 10:14 AM
    dragon
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    Thanks for the replies.
    Dyno operator was able to get everything running.
    First time ever on a dyno so learned a few things.
    Got a couple pulls as we had 10 cars to put through.
    278hp & 299 torque @ about 5500rpm.
    I have a slight coolant leak somewhere so I didn't want to push it too hard.
    The curve from what I remember was pretty erratic but i guess that was my twitchy foot on the skinny pedal of an automatic. :eek:
    After I pulled the truck off the dyno, I realized I had the A/C on :facepalm:
    In my defence, the ram mounts for my iPad & iPhone covered the A/C button.
    I figure if I had pushed it to 6000-6200rpm & had the A/C off, my number would have been pretty close to 300? Am I way off?
    For performance mods, my 2008 double cab long box 4x4 v6 auto has the trd S/C, apr X1, afe CAI, DTLT headers, DT y-pipe & some exhaust work (2 magna flow mufflers) that needs to be done since the S/C install.
    The UN-performance mods include AP front & rear plate bumpers, stubb's welding square-tubed sliders, 33" tires on 20" rims & living in a very high altitude city (for the americans, think Denver or Colorado Springs)
  6. Aug 24, 2014 at 5:35 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Ac didn't affect anything. It disengages at wot. Nice pull, post the graph when you have a chance.
