DynoLock Electric Tail Gate Lock Install
Discussion in 'Product Reviews' started by Wrekreation, May 10, 2009.
  1. Apr 16, 2012 at 8:55 AM
    #81
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Thanks I must have missed it.
  2. Apr 16, 2012 at 8:58 AM
    #82
    Rellik01
    Craig
    Windermere, Florida
    Exactly how much are you trimming. Are you just taking a little at a time "Trial and error"?
  3. Apr 17, 2012 at 8:15 AM
    #83
    amj24
    amj24 New Member
    Washington
    2011 4x4 SR5
    I have followed all of the helpful advice and pictures on this thread, I am just running into one problem.... I cannot find the blue/red or blue/black wires!!
    I have looked at all the pictures for wiring and I am certain that I am looking in the right place and those wires are just not there.
    Has anyone else ran into this problem?
    I will call Jim at Dynolock today.
  4. Apr 17, 2012 at 8:25 AM
    #84
    Wrekreation
    Wrekreation [OP] Member
    Northern Virginia
    09 Tacoma TRD
    roll top
    Entry #26 has wiring pictures
  5. Apr 17, 2012 at 8:50 PM
    #85
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    sub for future instal
  6. Apr 18, 2012 at 3:33 AM
    #86
    Whiplash777
    Whiplash777 Well-Known Member
    Upstate NY
    '09 Blue Double Cab Off Road
    Side steps, DRLs, DynoLock
    Be sure to look inside the black plastic sleeve (you know, the one that's wrapped with about 50 yards of black tape). Once you get to all the wiring, you may need to roll the wires around to find the stripes (pretty much all of my wiring was solid blue up, stripe down).
  7. Jul 15, 2012 at 11:44 PM
    #87
    Hawaiianguy
    Hawaiianguy Member
    I have a 2012 Prerunner Access cab. Could not find the blue/red (pink), blue/black wires by the front seats or access cab so I called Jim on a Sunday. He was glad to help. He said I needed the look in either of the kick panels and sure enough they were there. I used the kick panel on the passenger side and the lock activates with the passenger side door lock. I wanted it to activate with the driver's side lock so I believe it would have worked if I used the driver's side kick panel.
  8. Aug 12, 2012 at 8:53 AM
    #88
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
  9. Sep 13, 2012 at 3:22 PM
    #89
    wreckshop
    wreckshop New Member
    Las Vegas, Nevada
    11 TX Pro
    Debadged, Dynolock, BakFlip, Locking Gas Cap.
    It has been about a year and a half since I installed my Dynolock. Since I was unable to open my gate by using the normal key fob/power door locks, I had to manually open up the gate after removing the internal panel.
    I found that the actuator install was loose because of a missing screw. The screw had loosened over time and fell out of place.
    Although I used threadlocker on the screw to anchor the actuator and frame to the handle/gate, I did not use any treadlocker on the smaller screws that hold the actuator to its aluminum frame (with nylon block).
    This time, I reinstalled the actuator, frame, and block with a generous amount of threadlocker on all screws.
    Hopefully, I don't get locked out of my bed for at least another two years.
  10. Nov 3, 2012 at 1:53 PM
    #90
    br8veheart
    br8veheart New Member
    Oklahoma
    I just got done installing my dynalock. I want to thank everyone for the tips and pictures it was extremely helpful. Wiring was easy, but running the cable was the worst part if you could call anything about it tough.:D
  11. Sep 7, 2020 at 8:10 AM
    #91
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I know this is old thread but I want to ask if everyone’s Dynolock is still working
    I want to do this mod.and it seem this product is better pop n lock
    GRNT4R likes this.
