Dynos
Discussion in 'Performance and Tuning' started by Icepuck72, Sep 26, 2011.
  1. Sep 26, 2011 at 6:57 AM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Trying to figure out which exhaust to put on....TRD, Magnaflow...etc....but not seeing any dynos done on our trucks.
    I would like a little deeper sound, but really want a little bit of performance as well. Definitely don't want to lose power...as I'm reading with the Flowmasters. :confused:
    Has anyone done any dynos before and after?
  2. Sep 30, 2011 at 9:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The TRD will net you the mildest sound and mildest increase in power. It is 2.5", but before the muffler reduces down in diameter before and after the muffler. Not the best for performance. Look at other brands. JBA, Banks, URD.
  3. Sep 30, 2011 at 9:48 AM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Check out the Aero Turbine 2525XL.....never had it on a dyno, but I feel like the truck is a little bit faster in the higher end RPMS, and it sounds great....definitely did not lose any power
  4. Sep 30, 2011 at 3:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Mine is 2.5" thru out. Also, I saw about 5 hp, which is about the same as the others out there, except the Dynomax Super Turbo, which gave an 8 hp gain.
  5. Oct 5, 2011 at 8:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could you take a picture of the tubing where it enters the muffler, and leaves the muffler?
  6. Oct 7, 2011 at 11:33 AM
    KAWAIANIANI
    KAWAIANIANI Well-Known Member
    TRD BLACKED OUT
    Weather tech stone deflector, Craven speed stubby antennae,DTLT and rear O2 Sims, URD Y pipe, 40 series flowmaster w/ 3" piping. Urd maf calibrator, TRD supercharger, TRD CAI.
    Does anyone have actual Dyno sheets(not from the man. website) actually showing any gains or losses?
  7. Oct 7, 2011 at 11:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I "had" quite a few. Evidenty, My Wife thought they were all trash a while back.....
