Dynovalve by SaviCorp
Discussion in 'Performance and Tuning' started by Special_K, Oct 6, 2010.
  1. Oct 6, 2010 at 10:29 PM
    Special_K
    Special_K [OP] o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    Anyone using a Dynovalve or know anything more about it??
    for $400...eek :notsure:
    DynoValve ®
    Dyno: An instrument designed to measure power, exhaust emissions, and fuel economy.
    Valves: Devices that regulate the flow of gases through apertures by opening and closing.
    DynoValve ® Overview
    In the 1960's, the Positive Crankcase Ventilation (PCV) System appeared on new American domestic cars. Not since the first engine exhaust emission control system has there been such a significant advancement in PCV valve technology as our DynoValve ® products.
    The DynoValve ® (gasoline) & DynoValvePro ® (diesel) are the first and only electronically controlled PCV/Crankcase Oil Recovery Emission Control Systems available.
    The EPA laboratory has accepted test results on the gasoline and diesel engines. Tests show that there was a reduction of all exhaust emissions, especially in the NOx, while simultaneously reducing fuel and oil consumption. Depending on the application, test reports will be available upon request. ​
    DynoValve
    • Improves Fuel Mileage
    • Reduces HC, CO, and NOx Exhaust Emissions
    • Laboratory Tested at EPA Approved Facility
    The DynoValve ® is a newly patented Positive Crankcase Ventilation (PCV) Valve. The DynoValve is designed for use in Automotive gasoline powered vehicles. The DynoValve ® replaces OEM PCV valves. The DynoValve [SIZE=-2]TM[/SIZE] eliminates the vacuum problems associated with todays standard PCV valves by optimally regulating the flow of engine blow-by gases. SaVi Media Group, Inc. accomplished this unique ventilation with the use of an electronically controlled switch. The Electronically Controlled DynoValve ® precisely regulates the flow of blow-by gases returning to the engine intake system. ​
    DynoValve® Complete Kit
    http://www.savicorp.com/FeatureProducts.aspx
  2. Oct 6, 2010 at 10:43 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    looks like a pile o' shit
  3. Oct 6, 2010 at 10:57 PM
    Special_K
    Special_K [OP] o_o
    Eddie
    Alameda, CA
    bump
    for anyone who's knowledgeable about this kind of thing
  4. Oct 7, 2010 at 6:15 PM
    Special_K
    Special_K [OP] o_o
    Eddie
    Alameda, CA
    bump
    no one?
    ...may have to revert back to Jonah's "pile o' shit" contention lol
  5. Oct 7, 2010 at 8:06 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I call serious bullshit on improving gas mileage... MAYBE 1mpg if that
    So besides improving gas mileage which is questionable and not proven to increase on Taco's by installing this device, unless you are Greenpeace activist and you seriously care about emissions, than I see absolutely no point in installing that device...
  6. Oct 7, 2010 at 9:06 PM
    Special_K
    Special_K [OP] o_o
    Eddie
    Alameda, CA
    Greenpeace...pffff
    yeah there hsn't been testing done on a taco and even the vehicles that were tested didn't see an increase in mpg enough to raise an eyebrow
  7. Aug 5, 2013 at 3:14 AM
    Darto
    Darto New Member
    Today on Stossel's news commentary show on Fox News, the SaviCorp Dyno Valve received very favorable report by Lauren Fix who has car maintenance website. Supposedly she had test runs and found this device one of the very few she had tested that yielded positive enough results to make it worth the cost of purchase. She stated that major automobile companies are planning on having this or a similar system on new models in a year or two. She claimed auto makers believe in this new type of electronic PCV valve replacement technology. Lauren Fix has a website. Most of what she had to say today about various products was very skeptical, but she apparently believed in this product very highly.
    To me it seems to good to be true...
  8. Aug 5, 2013 at 4:41 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What's wrong with the OEM PCV valve to warrant "fixing" with this thing?
  9. Aug 5, 2013 at 6:01 AM
    Darto
    Darto New Member
    http://www.savicorp.com/Reports/D-677.pdf
    Emissions and fuel savings supposedly are improved. Others above say it reduces emissions but they are not sure of fuel savings. California has certified it reduces smog (link above).
    If it reduced (or increased) mileage by 10% I probably would not notice the difference as I don't drive the same routes in every tankful, measuring would be difficult without a rigorous test. And it takes a long installation process, I would guess half an hour for a typical, so would take a real commitment to try it out by first installing, uninstalling, reinstalling, etc.
  10. Aug 5, 2013 at 2:44 PM
    KenLyns
    Belly of the Beast
    What is the scientific mechanism by which it improves gas milage? Does it filter better or worse than the stock PCV valve?
  11. Aug 5, 2013 at 3:51 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    No other news reports ??
    There's your clue to COMPLETE BS.
