E 85
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benny238, Apr 14, 2022.
  1. Apr 14, 2022 at 7:38 AM
    Benny238
    Benny238 [OP] New Member
    2016 tacoma
    Hello I got a 3rd gen tacoma and I’m tryna to convert it to E85, Any suggestions on what injectors to get and what kit ?
  2. Apr 14, 2022 at 7:42 AM
    Shellshock
    Iowa
    Why?
    Dso101 likes this.
  3. Apr 14, 2022 at 7:51 AM
    Benny238
    2016 tacoma
    More horsepower, it runs way smother and it’s cleaner, also there’s not that much tacomas out there on E85
  4. Apr 14, 2022 at 7:54 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    reallifedog and Red Alert like this.
  5. Apr 14, 2022 at 7:59 AM
    ridefastflyfar
    ridefastflyfar Well-Known Member
    Tasche
    Hailey, ID
    '02 DCSB, '19 DCSB, '78 FJ40
    I thought the horsepower 'gains' were just from running leaner/more advanced timing. You're getting less energy per gallon out of ethanol than gas, so consumption will go up for the same amount of work.
    What are you planning to do for timing control and fuel delivery?
    Speedytech7 and Dm93 like this.
  6. Apr 14, 2022 at 8:06 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You could probably do it with just tuning if the rest of the fuel system can handle the alcohol, have you checked with any of the tuners that lurk on here?
    TnShooter likes this.
  7. Apr 14, 2022 at 8:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    theres going to be almost zero benefit on an NA'd tacoma to go through the hassle to go E85. Also... this is the 2nd gen section.
  8. Apr 14, 2022 at 8:50 AM
    Shellshock
    Iowa
    It’s also less efficient and you’ll need tuning in addition to fuel system upgrades. No one has done it on a NA truck, they haven’t even done e85 on FI trucks yet.
  9. Apr 14, 2022 at 8:53 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  10. Apr 14, 2022 at 8:56 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Sure, start another E85 thread 15 minutes after another one was started.
    https://www.tacomaworld.com/threads/e85.762544/
    The fate of this thread will be the same as all other E85 threads - deletion.
    Toyota engine and fuel systems were NEVER designed for E85 (or anything other than Unleaded Fuel Only).
    23Skidoo likes this.
  11. Apr 14, 2022 at 9:06 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    reallifedog and PzTank like this.
  12. Apr 14, 2022 at 9:55 AM
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Try splashing 4-5 gallons of E85 per tank full to get you to roughly E30. That should give you most of any power gains you're likely to achieve without going to different injectors/specific tune, and no worries about harmful effects of alcohol on certain parts of your fuel system.
    JayRolla likes this.
  13. Apr 14, 2022 at 10:07 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This ^^^^
    Total waste to even contemplate going E85 in a Taco. If you want more HP, smoother, cleaner or what ever then get a different vehicle.
  14. Apr 14, 2022 at 9:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    corn is no cheaper than dinosaurs in this day and age, leave well enough alone.
  15. Apr 14, 2022 at 11:09 PM
    EdsNotHere
    EdsNotHere Well-Known Member
    2011 Pre-Runner Double Cab
    Yeah what they said. E85 and a stock Tacoma is actually going to lose you horsepower. You can change injectors and make it like a Ford flex vehicle but what’s the point. I ran about an E30 to E35 mix in my TwinTurbo genesis G70 but it was boosted almost 20 psi. So unless you’re putting on a supercharger and just spinning your wheels (no pun intended).
    6 gearT444E likes this.
