E-bikes anyone? (bicycles)
Discussion in 'Sports, Hobbies & Interests' started by rob feature, Apr 25, 2020.
  1. Oct 30, 2023 at 7:51 AM
    #121
    BattlecryTaco
    BattlecryTaco Well-Known Member
    So Cal
    3rd Gen TRD Off Road DCSB
    Not sure if HF sells these VersaHaul racks, but it looks like you can find some online:
    https://versahaul.com/vh55dmro.php
    or this more affordable option:
    https://m.vevor.com/hitch-motorcycl..._nwPOJ7kTCGn57CC1ssCdLcXMljMHbtQaAjCSEALw_wcB
    Pablo8[QUOTED] likes this.
  2. Oct 31, 2023 at 3:39 PM
    #122
    BattlecryTaco
    So Cal
    The 1UP RakAttach (size large) with the Hollywood Rack Sport Rider combo is on. Gotta test it out on the freeway and on the trails. Departure angle is gonna suck; so, I gotta practice on some garage driveway ramps to see what the new setup can handle. At least I got more clearance in the back now so that I can mount the emtb onto the nearest tray to the tailgate without the handle bar jamming into the rtt or bedrack.
    Pablo8 likes this.
  3. Jan 6, 2024 at 8:54 PM
    #123
    slvrtaco11
    slvrtaco11 Well-Known Member
    SF bay area
    2018 TRD OFF ROAD AC
    tint, oem bed mat, CVC tune
  4. Feb 5, 2024 at 2:16 PM
    #124
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I recently completed my eBike build. I converted my custom build 2003’ish Nashbar frame mtn bike to a mid drive. My motor is a 52-vokt 1K watt BBHSD, but I’m starting off with a 48-volt battery, I got a UPP 19 mah with LG cells. Adding a 42T chainring and Eggrider display, among other little things, my conversion came in to about $1200. The bike weight is just under 60 lbs. I can hit 30 mph unassisted and got 57 miles on my first battery charge. Not bad considering I went full throttle several times and reside in a hilly area. Once I start riding conservatively, I expect my battery range to go past 70 miles, maybe 80.
  5. Feb 5, 2024 at 5:32 PM
    #125
    rob feature
    rob feature [OP] Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    That's pretty respectable range for mostly motor on knobs. I'd still like to have a throttled build - maybe a fatbike or sommat to blast through snow and sand, but the last time I looked, it was really hard to get parts - especially batteries.
  6. May 16, 2024 at 6:59 PM
    #126
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    For out on my Levo today. 33 miles and 5000ft of climbing.
    hack4875 likes this.
  7. May 18, 2024 at 4:26 AM
    #127
    CassND
    CassND Well-Known Member
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    IMG_2081.jpg IMG_0776.jpg IMG_1390.jpgHere’s what the wife and I ride. The trikes are super fun.
    hack4875 and woodtickgreg like this.
  8. May 18, 2024 at 4:38 AM
    #128
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    The trikes are interesting. Where is the motor located?
  9. May 18, 2024 at 4:40 AM
    #129
    CassND
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    on the end of the tad pole.
    Chuy and woodtickgreg like this.
  10. May 18, 2024 at 4:53 AM
    #130
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    My build was very similar, 52V 20AH Batt, 1500W BBSHD, Eggrider display, Lekke 40T chain ring and wide ratio rear cassette. course it's got a throttle and suspension seat post. There's allot of sand around here and a typical bike just sinks into it, I went with a fat tire bike to be able to ride out in the desert here which it does well.
    It works pretty well, does about 32mph and has a range I've never come close to using, I could if I felt like doing a 50mi bike ride which I don't. It doesn't compare to the high end bikes except in speed and range. Handling is crude as you'd expect but it will climb a very steep incline to the point where the back wheel spins or the bike loops out.
    Chuy[QUOTED] and woodtickgreg like this.
  11. May 18, 2024 at 5:00 AM
    #131
    woodtickgreg
    Greg
    Michigan
    Very cool mid drive set up. I bet those trikes where pricey. But they do look super comfy and fun.
  12. May 18, 2024 at 5:09 AM
    #132
    CassND
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    Unfortunately, yes they are pricey but, we don’t have a lot of hobbies so……why not; right? :)
    Chuy and woodtickgreg[QUOTED] like this.
  13. May 18, 2024 at 11:12 AM
    #133
    Chuy
    Lakeside, CA
    Silver Taco
    Very nice. What range is your rear cassette? Mine is 11-32 8 speed, but I have a 11-42 I will put in after a little more usage with the current setup. I cheaped on the chain ring, I got one off aliexpress with the 20mm offset and it is holding up well. I do love that Eggrider.
    I recently took it on my first offroad ride on a very steep and rutted fireroad. With two miles to go on the way back my left side crank fell off the bike. I come to find out this is a known issue with the BBSHD - the crankarm bolt gets loose and can come off. I installed a new bolt with gobs of blue threadlocker. If it happens again, I will use red locker.
  14. May 18, 2024 at 12:35 PM
    #134
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    About three years ago I put a Bafang HD 48V on my GT Richter 8. It's great in every way I need a bike. Typical range between recharge is 100mi. and it's uphill both ways no matter which way I go ;-) I pedal A LOT!. Seldom use pedal assist past 1/2 power.
    I carry the crank bolt allen key in the saddle bags! ;-)
    eta
    This year I did put on a "wide ratio" casset Don't recall the tooth count, But one tooth up and one tooth down from the original (7 speed)
    Chuy[QUOTED] likes this.
  15. May 18, 2024 at 7:48 PM
    #135
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I'm using a 11/46 cassette
    https://boxcomponents.com/products/box-three-p9-wide-multi-shift-groupset
    That big of a 1st gear requires a long arm derailleur which is part of their kit. The friction clutch on their derailleur also puts allot more pressure on the chain tension. Before that if I was hauling ass in some rough stuff it'd sometimes throw the chain from the derailleur flopping up and down.
    What I kinda discovered was having a really strong gear setup and good chain made it pretty much bulletproof. Before that i'd break stuff if I didn't watch it. For me the e-bike is a great way for an old guy like me to hit some trails that I'm not allowed to on my dirtbike and pedalling is optional, I like to say I rest on the uphills.
    The bike riding near my home is all desert so fat tires are mandatory, anything narrower just sinks in the sand.
    ricphoto, woodtickgreg and Chuy like this.
  16. Jun 19, 2024 at 10:26 AM
    #136
    griplimited
    griplimited Active Member
    Have a folding style ebike. 20x4 tires. Super fun, easy to put away. Been thinking of ways to have an extended battery
    woodtickgreg likes this.
  17. Jun 25, 2024 at 7:30 AM
    #137
    griplimited
    Car battery died. Took my ebike. Rode it, more like just breezed, to local auto parts for a replacement.
    woodtickgreg and ricphoto like this.
  18. Oct 23, 2024 at 6:02 PM
    #138
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Haven't been here for a while, but I ended up sending it back because it was a lemon.
    But for the time I did have it, I learned that I cannot balance on a two-wheeler the way I could when I was younger. #OldAgeSux
    So I went out and got this one. Last month I did a 150-mile ride from Pittsburgh PA to Cumberland MD on the Great Allegheny Passage rail rail; four days and three nights.
    Here it is, outfitted for the trip.
